  1. Hello!
    Is it possible to add any text or picture to my recorded file or while recording live stream in this player? I cant to find anything : (
    regards John
  2. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    It is possible with overlays using several programs including ffmpeg and/OR avisynth. Are you looking to add in just one spot for the length of the movie or several for short spans? Will you use both picture and text? Will they overlap or not?
    A little more information would make it easier to give a more detailed answer and example.
  3. i would like to add my own logo like it is possible in VLC "overlay". i have seen this avisynth script but no idea how to use it.
  4. Member Budman1's Avatar
    Jul 2012
    For my overlays I use FFmpeg to hardcode the AVIsynth script setup. The setup for my example is shown below:
Name:	overlay setup.jpg
Name:	overlay ffmpeg.jpg
    The avisynth script is:
    v1 = Directshowsource("C:\Users\Bud\Desktop\Wham!Last Christmas.mp4").ConvertToRGB32.Lanczosresize(640, 360)
    img1 = ImageSource("C:\Users\Bud\Desktop\imagefolder\TransparentBG.png", pixel_type="RGB32", fps=30.000, end=8335).converttoRGB32.LanczosResize(114,76)
    clip1 = v1.trim(0, -8335).Overlay(img1, 10, 10,Opacity=1.0, img1.ShowAlpha())
    return clip1
Name:	overlay script.jpg
    Which results in the video:
Name:	Overlay Video.jpg
  5. There is a simple trick but it is only possible in live version (not mini).
    Pressing casting button will open the following dialog.
    The option "Apply broadcast effects to on-air..." should be disabled.
    note: don't press the buttons of the dialog below.
