Hi everyone, new here, with a new problem!
I'm using PotPlayer as my main playback program these days, it's great but I'm having a hard time figuring out one thing:
If I'm playing a playlist in shuffle mode, is there a way for each item to be played only once? What's happening at the moment is videos are getting repeated even before every other item on the list has been played, I'd just like to be able to shuffle a playlist without seeing the same videos twice... This used to be an easy enough thing to do with VLC, but ideally I'd prefer to use PotPlayer.
Here's how I've found to do it:
- Add the songs you want to play to your playlist. (I prefer to select them in a file window, right-click one of the selected files, then click "Add to PotPlayer playlist".)
- In PotPlayer, if the playlist isn't visible, press F6 to show it.
- Right-click any song in the playlist; point to Sort, then click Randomly. (I couldn't get the shortcut shown there, Ctrl+F9, to work.) The playlist is sorted in random order.
- Click the first song in the list to select it, then click the Play button. PP plays through the list as shown, without repeats (unless you have repeating set in general).
There also seems to be a bug (in the version I'm using, at least) that prevents further songs from being added to the playlist once Random sorting is selected. Maybe it'll be fixed by the time you read this.
Potplayer Playback logo?
By hosty in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2025, 15:54 -
PotPlayer - Play Previous with Shuffle
By Monokuma in forum Software PlayingReplies: 1Last Post: 14th Nov 2024, 01:55 -
PotPlayer playback problem
By IceToad in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2013, 06:29 -
Problems with playback on PotPlayer
By TheGreeneYonder in forum Software PlayingReplies: 1Last Post: 4th Mar 2013, 22:20 -
Potplayer playback problem
By halserrano in forum Newbie / General discussionsReplies: 4Last Post: 27th Sep 2012, 16:04
