I was told, when inquiring on a motorcycle forum, that mounting my Sony Handicam on my motorcycle was a bad idea. The instrument (Handicam) is too delicate and would probably incur internal damage.
What say ye?
I was looking at RAM Mounts for mounting to the handle bar but I didn’t see anything stating vibration free or shock resistant.
I wouldn't risk a camcorder on a semi-rigid handle bar mount. You might look into a camera less susceptible to damage.
GoPro is one, but I use a Mobius camera, about the size of a matchbox. Even with it, high rates of vibration can cause
a 'jello' affect in the video. If you have a heavy street bike, maybe not a problem.
But a Mobius is cheap enough (~$80US) and takes great HD video.
Wind noise can be a problem, but I use a fabric Band-Aid over the microphone and that helps.
Mobius: https://www.amazon.com/Mobius-Action-Camera-1080P-Sports/dp/B00DP1WYD2/ref=sr_1_1?s=el...n+camera&psc=1
I also use a 1400mAh 5VDC battery pack and a 128GB micro SD card for about 7hours of HD video.
If you really want to use your camcorder, I would make a custom mount that surrounds the camera in soft foam.
That may prevent damage.
Buying a monitor mount
By A Traveller in forum ComputerReplies: 6Last Post: 22nd Dec 2016, 23:26 -
Pismo File Mount ponting directory
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 11th Nov 2015, 04:07 -
Laptop Wall Mount
By SIRCOOKS in forum ComputerReplies: 2Last Post: 12th Aug 2015, 13:29 -
How 2 Mount Softboxes 2 Ceiling or Beam?
By sdsumike619 in forum Off topicReplies: 5Last Post: 1st Jul 2015, 01:24 -
Does anyone know what I could use for for a camcorder mount?
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 22nd Sep 2013, 17:47
