I want to convert a mkv file to a "normal" bluray to see in the player of computer. I used mkv2vob for direct stream, but the video stuttering.There is a better program than mkv2vob?
Why don't you use a PC software that can play MKV files? Like MPC-HC or VLC?
From your description it sounds like you want a workaround for a problem but you didn't tell us much about it. PC specs? OS? Player software used? File you are trying to play? "Mkv" can be many things, we'd need a sample or at least the MediaInfo log. -
You might try multiAVCHD or AVCHDCoder if you want a 'normal' BD to use in a set top player.
For computer playback, why change it? Just burn the existing MKV to a disc as data with ImgBurn if you want it on disc.
Either way, the size has to fit the media.
Burning MKV to BLURAY DISC
By csiokos in forum Newbie / General discussionsReplies: 3Last Post: 26th Feb 2016, 14:13 -
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 17:10 -
Create Bluray (MKV->Bluray) with custom menu
By ThaDraGun in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Aug 2015, 19:52 -
MKV To Bluray or DVD Disc
By maverickluke in forum Video ConversionReplies: 7Last Post: 21st Jan 2015, 14:04 -
Did they ever make a bluray disc changer or a bluray/vhs combo?
By yoda313 in forum Off topicReplies: 4Last Post: 28th Mar 2013, 16:03
