    Apr 2017
    I'm not a person that makes a lot of dvds to play on a dvd player. But every once in while I need to make one. I've been using devede on linux mint for a year or so. I noticed at the end of 2016 that something changed. While the program was simply called devede it is now called devede NG. I was running version 4.4.0-1 because it is in the mint repositories. But due to some problems I downloaded the deb file for 4.8.8. I removed the first one and then installed the new one. The first problem I noticed with devede NG was that when I loaded in several videos and made a dvd what played back was not in order of the titles. This time around I have no idea if the versions I'm using has that problem or not. But the biggest issue I'm having now is that every time I convert a mp4 file into the iso file for burning a dvd, the result is blurry video. I made a 9 minute video showing what I'm doing. I hope if I'm doing anything wrong you can point it out for me.
    https://www.youtube.com/watch?v=6wOBto2Uz9E
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Your test clip source file is a screen capture with small text. That is, the finest details are computer screen resolution. (Which is what? 1920x1080 perhaps?)
    DVD resolution is much smaller: 720x480 (for NTSC), which is not 720p, but 480i. If you blow that up to full screen, it will get blurry, as each pixel of information gets stretched out over 6 pixels on screen (2.67×2.25). That is of no fault of any software, that is just the limit of DVD-Video.
    Your software is fine, I guess you expected too much of DVD: it is not HD.
    Apr 2017
    I don't understand it because when I had the older version of devede it worked just fine. Here is what I mean:
    Currently I'm running Linux Mint 18 on this system:
    System:    Host: asus-z170m-plus Kernel: 4.4.0-75-generic x86_64 (64 bit gcc: 5.4.0)
               Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18 Sarah
    Machine:   Mobo: ASUSTeK model: Z170M-PLUS v: Rev X.0x Bios: American Megatrends v: 0704 date: 02/18/2016
    CPU:       Quad core Intel Core i5-6600K (-MCP-) cache: 6144 KB
               flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 28032
               clock speeds: max: 4200 MHz 1: 799 MHz 2: 799 MHz 3: 800 MHz 4: 799 MHz
    Graphics:  Card: NVIDIA GM107 [GeForce GTX 750 Ti] bus-ID: 03:00.0
               Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
               Resolution: 1920x1080@60.00hz
               GLX Renderer: GeForce GTX 750 Ti/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 370.28 Direct Rendering: Yes
    Audio:     Card-1 NVIDIA Device 0fbc driver: snd_hda_intel bus-ID: 03:00.1 Sound: ALSA v: k4.4.0-75-generic
               Card-2 Intel Sunrise Point-H HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
    Network:   Card: Intel Ethernet Connection (2) I219-V driver: e1000e v: 3.2.6-k bus-ID: 00:1f.6
               IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
    Drives:    HDD Total Size: 515.8GB (10.1% used) ID-1: /dev/sda model: HGST_HTS725050A7 size: 500.1GB
               ID-2: USB /dev/sdb model: Cruzer_Glide size: 15.7GB
    Partition: ID-1: / size: 443G used: 33G (8%) fs: ext4 dev: /dev/sda1
               ID-2: swap-1 size: 17.10GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
    RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
    Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 0.0:32C
               Fan Speeds (in rpm): cpu: 0
    Info:      Processes: 200 Uptime: 5:25 Memory: 1992.7/15971.2MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
               Client: Shell (bash 4.3.421) inxi: 2.2.35
    When I tried MX-15 which is a linux distro based on debian: The devede in the repositories was an older version. Everything worked exactly right. I play 720 videos on this computer all the time! I also play 720 dvds on my TV all the time. They are never this blurry. I don't think this version of devede is out putting something correctly. I just don't know what to do about it.
    Apr 2017
    I did a lot of testing. I think your right. I don't understand why things used to turn out better for me. The only thing I can come up with is I must have been delusional.
  5. Originally Posted by gregorylock View Post
    More likely you were working with video that didn't have sharp text.
