OK, I converted an SD video to mkv, loaded it on Virtualdub and tried several filters to enhance it. mostly sharpening and adjusting contrast. Subtle, but effective.
Now I need to process the whole video, but I don't know what compression plugin to use for better quality and how to set it up.
I know I do need to use compression, as the last time I tried that with another video, the video size was around 70Gb.
So I need to know if there's a way to adjust the final size.
Results 1 to 11 of 11
"OK, I converted an SD video to mkv" Why?
What do you want to do with it?Last edited by KBeee; 25th Apr 2017 at 19:34. Reason: Cos the question was inexplicable
VirtualDub (the original one by Avery Lee) only supports the AVI container as output, and only VfW codecs as compressors. Any modern and efficient video compression format does not belong into the AVI container anymore, though. Even though x264vfw and x265vfw do exist, I would not recommend using them to create an AVI file with AVC or HEVC video.
From version 1.10 on, VirtualDub also supports the definition of external encoders and multiplexers. This way you could encode e.g. with x264 to AVC and multiplex it into MP4 or MKV. But setting VirtualDub up to handle the required tools is a bit elaborate.
VDubFilterMod includes x264 in the list of compressors (Ctrl+P) with a more modern interface, and it can also write MP4 or MKV. This workflow may be suitable to you. You will have to "Configure" the compressor's "Rate control" to either a quality level (CRF), or calculate a desired target bitrate (this will require 2 passes for both optimal quality distribution and matching target size). -
I want to make the video look better. The transfer is very poor. And mkv is a better format."OK, I converted an SD video to mkv" Why?
Where do I get VDubFilterMod? Google didn't find it.VDubFilterMod includes x264 in the list of compressors (Ctrl+P) with a more modern interface, and it can also write MP4 or MKV. This workflow may be suitable to you. You will have to "Configure" the compressor's "Rate control" to either a quality level (CRF), or calculate a desired target bitrate (this will require 2 passes for both optimal quality distribution and matching target size). -
What did you convert it from? In other words, can you load your original file into Virtualdub or Virtualdub ModFilter and save yourself some time? (Don't forget that there are loads of additional filters that can be added to either Vdub or Vdub ModFilter, you're not stuck with just the ones that came with it.)
Last edited by TimA-C; 26th Apr 2017 at 13:16. Reason: ****-up on the keyboard front!
Hi LigH.de thanks for pointing out that I'd had two ****-ups on the keyboard front! D'oh!
Nothing like having your shortcomings flagged up and mocked at the same time!
Well, at least we know now which name VideoHelp recognizes and links automatically to the matching software page.
How to compress a video?
By Qayyum in forum Newbie / General discussionsReplies: 9Last Post: 17th Mar 2016, 08:52 -
Best way to compress video with least difference?
By Dan-D-Pak in forum Video ConversionReplies: 3Last Post: 11th Aug 2015, 13:09 -
(re) compress video files
By agent222 in forum Newbie / General discussionsReplies: 5Last Post: 15th Nov 2012, 18:26 -
How to compress video files
By ramosis in forum Newbie / General discussionsReplies: 18Last Post: 4th Nov 2012, 12:45 -
virtualdub compress multi files??
By celebiii in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2012, 02:18
