  1. Member Ennio's Avatar
    May 2005
    Netherlands
    Hi everybody,
    When I open a .mpls file (in the playlist folder of a BD folder structure), MediaInfo doesn't show a result window anymore (it always used to in the past).
    In taskmanager, mediainfo.exe *32 keeps being busy though. I especially mention the *32 because I don't know what that means.
    I am running the latest 64 bit portable version in Win7 64 bit...
    Anybody know what the problem might be?
    Thanks in advance
    Ennio
    Edit: I found out this is happening only with the latest version MediaInfo_GUI_0.7.94_Windows_x64_WithoutInstaller
    I went back to previous version 0.7.93 and things work like a charm again. A bug that will be fixed with next update...?
  2. Member Ennio's Avatar
    May 2005
    Netherlands
    Encountering exact problem with latest version MediaInfo_GUI_0.7.95_Windows_x64_WithoutInstaller
  3. Bugs tend to not get fixed quickly or at all if you don't report them at the appropriate place. Someone else did it for you now.
    https://sourceforge.net/p/mediainfo/bugs/1050/
  4. I have problems with the latest release and exporting. I keep getting a sidecar load error
    Originally Posted by jagabo
