Hi, im about to buy a new am3+ mb and processor and the ram slot is ddr3, but with ddr3 ram still quite expensive i was wondering if you could backtrack to ddr2 memory and use that in a ddr3 slot, obviously it wont work aswell as ddr3 but would still do a job
Thanks in advance for any info
The RAM must be a supported type and speed. A motherboard which only accepts AM3+ CPUs can't use DDR2. AM3+ motherboards can use either DDR3 1066 or DDR3 1333 if the system is not overclocked. If you buy DDR3 1333, you may need to change a BIOS setting to use DDR3 1333 at its rated speed.
[Edit]DDR2 RAM won't work in a DDR3 slot. The voltage is different, and even if both have 240-pins, they have a different key notch location, and different pin-outs. Any motherboards which support both DDR2 and DDR3 have designated DDR2 slots and designated DDR3 slots.Last edited by usually_quiet; 23rd Apr 2017 at 12:56.
can ddr pci video card work on ddr2 motherboard?
By Frank-0-Video in forum ComputerReplies: 2Last Post: 30th Apr 2014, 19:40 -
Ddr1/ddr3
By LabanB in forum ComputerReplies: 7Last Post: 18th Sep 2013, 04:57 -
How much RAM do you do you actually need?
By Moontrash in forum ComputerReplies: 16Last Post: 1st Oct 2012, 03:13 -
Configuring LG Full HD screen on GeForce GTS 250 1GB DDR3
By iceq in forum DVB / IPTVReplies: 15Last Post: 29th Aug 2012, 11:23 -
Possible RAM upgrade?!
By Squid_uk in forum ComputerReplies: 20Last Post: 5th May 2012, 18:01
