I have a Hero 4 Silver, my wife bought it for herself and it drove me nuts trying to match the footage to my camcorder in post. Main dislikes are barrel distortion, a colour balance that seems to keep changing and soft image quality after distortion correction. Then again, it's a handy little camera for many uses and deserves a little perseverance and understanding on my part.
I have seen many, often conflicting, tutorials and done some tests, this is why I ask for your advice. It would seem that if I shoot in 2.7k Wide, after correction losses I should finish up with good, sharp 1080 video. Also if I set White Balance to Native it should stay constant and be easier to correct and match in post. If not, what would you suggest? I have ProTune on, set to Flat with Exposure Compensation at -1 to try to achieve the highest dynamic range. Again, would you agree? Any other settings I ought to tweak?
Also I am considering getting a set of ND filters for it and was wondering if it's worth the effort. Any brand you would recommend (or avoid)?
Any advice will be appreciated.
Results 1 to 1 of 1
GoPro Hero 4 Black - Capture & Editing Advice
By BoroRob in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2016, 03:39 -
GoPro Session
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Apr 2016, 12:58 -
ND or CP filter for GoPro
By jucas85 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 22nd Dec 2014, 10:50 -
New GoPro 4 Silver
By budwzr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Oct 2014, 11:31 -
GoPro Deals
By budwzr in forum Off topicReplies: 0Last Post: 13th Dec 2012, 23:37
