Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. Any way to download this without purchasing a program?
    http://ffilms.org/easter-parade-1948/
    Thanks!
    Mar 2008
    Thanks!
    I can download this film on my android phone without any problems.
    Wait for it to start playing, then do a long press on the screen and in a second or two a menu
    appears and one of the options is "save video"
    When it's complete, simple matter to copy it to the PC
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Youtube-dl (CLI) seems to download it fine (slow, still in progress). Seems to be 1.04 GiB in size.
  4. youtube-dl command line:
    youtube-dl -c --title -f best https://ok.ru/video/35384199891
  5. Thanks. Never used youtube-dl before. I downloaded the Windows executable, but still don't know how to use it. Is there a FAQ that shows how to use it?
  6. It worked! Thank you very much!
  7. In case you want to know how the https://ok.ru/video/35384199891 link was obtained: Play the video at the web site. Once it has started playing right click on the video and select "Link to video", then in the dialog that appears press "Copy link". The link is now in the clipboard and can be pasted into a document.
