I recently bought a dvd from England and it says it cant read. My
DVD is a Panasonic DMR-XW300. Is there any way I can play this DVD?. Margaret
The problem is the region code. DVD's produced for one region won't play on players produced for another region:
https://en.wikipedia.org/wiki/DVD_region_code
You need a region free DVD player. Some players can be made region free via a sequence of button presses on the remote. Look for your player in the database here.
https://www.videohelp.com/dvdhacks
If you don't find your player you can make a region free copy with your computer (if you have a DVD writer). -
If it's a PAL DVD, you should be able to play it with that DVDR unless the region code is wrong.
But to copy it, that's a bit more complicated.
But others here may be able to give better advice.
And welcome to our forums.
And jagabo was faster.
Should be able to play the disc on your computer.
If you copy the disc it will be region free but the video
Will still be pal format, unless your TV can display PAL format
Or your dvd player can play pal format disc's. -
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 08:30 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 12:59 -
Panasonic MTS to DVD
By fastoy in forum Authoring (DVD)Replies: 1Last Post: 27th Jan 2013, 06:08 -
Panasonic dmr es15 wont read any divx or dvd on dvd rw-+
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 20th Oct 2012, 08:52 -
Panasonic won't burn DVD -R DL but used to!!??
By CoastR in forum DVD & Blu-ray PlayersReplies: 9Last Post: 28th Jun 2012, 00:51
