a couple of days ago there was a thread about takeing a file that was in pro logic and converting it to 5.1....now as far as i know there isn't a way to do it yet but here's my question and thought....if i were to rip a DVD can the 5.1 audio remain the same if i were to put it onto a cdr??? in other words, encode the video then multiplex the original ripped audio and the new encoded video......just a thought.........thanks......
um, ShiZZZoN has told me the program that makes DTS for our svcd\vcd movies because he owns all and he is my supplier.
MinneTonka Surcode DTS -
This has been discussed so many times on this forum its ridiculous. Just do a forum search.
In short, svcds support something called multichannel mpeg audio, which allows for 5.1 signals. You need to author the audio in linux in order for it to be compliant. You also need a Philips dvd player and a reciever that supports multichannel mpeg audio. You need either I-Author or Philips Svcd Designer (I think SVCD Designer can do it, not sure) to multiplex the svcd.
If you don't meet these requirements then give up on having the 5.1 signals in a vcd or svcd. Its simply not possible. Ali G WiKiT you would do well not to listen to Shizzzon because, yet again, it seems he has misinformed someone. That program is for creating DTS audio, which cannot be implemented in a vcd or svcd at all.
You could create a mini-dvd that used the original ac3 file, preserving the audio. Again just do a forum search if you want to give this a try but note that very very few dvd players will play this. You can check the dvd player compatibility list to see if your dvd player does.
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
I have no idea how much does this cost
By Artas1984 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jan 2012, 14:47 -
Simple Guide : How to convert DD5.1 AC-3 448 / 640 to stereo.
By Bonie81 in forum User guidesReplies: 3Last Post: 13th Jul 2011, 09:55 -
I just had a really funny idea, but no idea how to do it, help =)
By NukeyDoo in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 06:47 -
Viewing and Burning 1080i DD5.1-CtrlHD.ts.par2 files
By Sharkman in forum Newbie / General discussionsReplies: 7Last Post: 26th Apr 2008, 14:07
