I have six files, all generated on a Mac, all with the same specifications.
Files were generated on Final Cut Pro 6 (with some updates to 7.03).
I remember that last year I had something similar, I beleieve I downgraded my Quicktime to make it work. I've tried Quicktime 6.3 and 7.4.5, but that didn't work.
Operating on a Windows I need to read these files to convert them to a different file, but none of the programmes / codecs seem to be able to read the file.
I had Quicktime 7.78, I tried Quicktime Alternative. I have an up-to-date Klite pack. I tried various separate codecs. Everything is still the same.
Videoinspector shows the files as corrupt, while Mediainfo just spurts the below information. Any ideas as what to do?
Complete name : H:\Raoul1SJailLubja36Copy7B.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2005.03 (qt )
File size : 158 GiB
have you tried installing the Avid codec LE ?
http://avid.force.com/pkb/articles/en_US/Download/en392959
That helped me when i couldn`t open a certain QT file ..although i can`t remember the exact QT file type i had
might be worth a shot? -
Nothing...
Just thought to add that its an Apple Prores 422 MOV file.
It works just fine on a Mac BTW, so the files are def OK. -
Its most likely wrong setups in Final Cut Pro.
Gone crazy with installing all kinds of codecs... still nothing.
Mov (PNG) Video to h.264 or another codec
By Computerman1 in forum Video ConversionReplies: 6Last Post: 20th Apr 2016, 02:22 -
What codec do i need to play mov file from my digital camera in c-sharp ?
By Chocolade in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2015, 18:55 -
Uncompressed Mov - Lossless Codec ?
By PowerFalcon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 30th Aug 2015, 22:27 -
Problem with .mov file
By 204Jordan in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2013, 14:44 -
.mov to .avi, works vlc xvid, not wmp! problem file?
By langb in forum Video ConversionReplies: 2Last Post: 13th Sep 2012, 02:10
