I have an mkv file that does not output sound on my tv because of the audio format. Looking for a solution. thanks
So far i demuxed it and tried audacity and a couple of other programs to convert it but what comes out is just noise
When i open the file in any audio editors it says it cannot determine the format and it's asking me to choose attributes and rate (hz). I only know this:
Code:Audio #1 ID : 2 Format : TrueHD Codec ID : A_TRUEHD Duration : 1 h 59 min Bit rate mode : Variable Bit rate : 3 659 kb/s Maximum bit rate : 5 634 kb/s Channel(s) : 8 channels Channel positions : Front: L C R, Side: L R, Back: L R, LFE Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 spf) Compression mode : Lossless Stream size : 3.06 GiB (20%)
Results 1 to 14 of 14
Or from TrueHD to FLAC with AudioMuxer. Saves space.
PS: You have to update manually the files at "C:\Users\UserName\AppData\Roaming\AudioMuxer" , because they're not up to date. The files that gets installed are way too old.... Eac3to, libFLAC.dll, mkvmerge.exe & mkvextract from mkvtoolnix, MediaInfo CLI.exe...and maybe the 7z files in the "Encoding" Folder. All x32 bit.Last edited by xxAno...xx; 21st Apr 2017 at 00:31.
You can do it in one process using PopcornMKV Audio Converter https://www.videohelp.com/software/PopCorn-MKV-AudioConverter no need to demux or muck about with command line routines. Just load the file in and select what you want. The default settings are TrueHD to DTS
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
What is your goal?
Quality-wise FLAC because FLAC is a lossless compression (like TrueHD).
If you want to balance quality/file size then I would extract the (E-)AC3 core (if your source is a Blu-Ray it should have such a core). That's what I do, personally. I do not hear any difference to TrueHD/FLAC. -
That PopcornMKV Audio Converter looks like it would be useful- the download is a zip file with an exe file. When run, the program says it needs to download the toolkit. When I try to download, nothing happens- a progress bar appears but nothing downloads.
It seems that the program link is dead. What utilities are needed and how should this be set up on a PC? -
After you install the program there should be a a zip file called AudioConverterTools.ZIP that contains all the helper programs. just create a folder called Tools and put them in that folder. Try this site http://auto-download.com/download/get/IcrAUQqHei/audioconvertertools_zip.html
.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks netmask56. I was able to download the tools.
I do have a problem getting the program to actually convert anything. A window pops up for a second (getting info on the file) and no file appears in the output folder. I'll keep trying when I have time, but I've found that AVIDemux can do audio conversions as well.
I know this is an old message thread about an old program so ... -
I use it every week without issue but it is slow. It does take sometime for conversion
How to setup Daum PotPlayer to output TrueHD and DTS-HD
By c627627 in forum Software PlayingReplies: 9Last Post: 16th Feb 2022, 21:33 -
Demux BD audio: TrueHD and DTS-HD
By kalemvar1 in forum Blu-ray RippingReplies: 3Last Post: 22nd Nov 2016, 18:36 -
DTS-HD/TRUEHD Editing Guide
By Johnny Doe in forum AudioReplies: 1Last Post: 2nd Sep 2014, 02:04 -
Encode Blu-ray with Truehd 5.1/7.1 And DTS HDMA Passtrough
By monster15 in forum EditingReplies: 1Last Post: 31st May 2014, 05:50 -
TrueHD to DTS 1536
By zolee in forum AudioReplies: 0Last Post: 12th Dec 2012, 06:16
