Recently, I've been using an LGP Lite to capture my videos, and RECentral would always work fine.
I've now switched over to a Live Gamer HD and things are going wrong. The card itself works fine, as does the RECentral software... UNTIL I stop recording. Once I do that, the software stops working. Either a strange black square appears on screen or the RECentral software is frozen and cannot be opened until forced closed. You also cannot do any recordings until it's closed.
I've also noticed that if it doesn't crash, it instead CLOSES ITSELF DOWN and is no longer running. So I have to restart RECentral.
This happens while capturing a full screen game using the PC, but recording from a console seems to work OK.
I've tried stopping the recording BEFORE I exit back to the desktop and I've tried AFTER exiting to the desktop but nothing works. 95% of the test captures I did in a whole would result in a crash, leaving the captured video only 1Kb in size and clearly not watchable.
Basic specs are:
Dell Precision T3400
Intel Core 2 Duo E8400 @ 3GHz
4Gb DDR2 RAM
EVGA GeForce GTX 750 Ti 2Gb
500Gb 7200rpm HDD
EVGA CX550M 550w PSU
I've never had RECentral crash AFTER recording. Usually it crashes before recording, or after I open it. What could cause it to crash after recording stops?
Results 1 to 1 of 1
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 234Last Post: 31st Dec 2025, 19:15 -
[Avermedia] RECentral lost sound, Live Gamer HD C985
By Arothgar in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2017, 23:28 -
AVerMedia RECentral and separate MP3 files...
By PureChaosX in forum Capturing and VCRReplies: 1Last Post: 9th Mar 2016, 17:57 -
Yes I am recording HDMI HDCP over Avermedia LGP Lite Capture- simple
By BobbyGee in forum Capturing and VCRReplies: 8Last Post: 19th Sep 2014, 07:54 -
avermedia C127 using hard drive space when not recording
By shiggy74 in forum Capturing and VCRReplies: 1Last Post: 15th Apr 2014, 13:12
