Hi there Videohelpers i have an problem with dvd 29.970fps i tried to encode but ghosting still exist where scene changes it brings ghosting frame from previous frame to forward frame on scene changes. i tried few filter like : Tdeint, Tdecimate, Qtgmc, Srestore and some other but found no luck with them or maybe i am not doing it correctly. it would be so nice if someone could please find a solution for this issue.
Here is a video sample : https://www.sendspace.com/file/0lon46
Forget about trying to fix it as it's worse even than the usual Indian garbage. Even ExBlend and SRestore didn't do much with the blends.
See if this gives results you may like. I do not think you will be able to remove it 100%, but you can try to reduce it's visibility some.
SRestore(frate=23.976) -
Anime DVD- need help with Frame Blending/Ghosting and mb some other tweaks?
By Mr.Brown in forum RestorationReplies: 3Last Post: 29th Jun 2015, 17:25 -
Another PAL DVD ghosting/blending problem
By pub in forum Video ConversionReplies: 2Last Post: 16th Feb 2015, 18:59 -
Another Ghosting Issue/Frame Blending Dillema
By hizzy7 in forum RestorationReplies: 136Last Post: 16th Feb 2014, 11:12 -
Frame Blending/Ghosting/Bad Interlacing Help
By EddyBund in forum RestorationReplies: 7Last Post: 2nd Jan 2014, 13:03 -
By hizzy7 in forum RestorationReplies: 12Last Post: 18th May 2013, 22:31
