I have a big video file (>8 GB) with an MPEG-4p10/AVC/h.264 encoded video part and an AC-3 encoded audio part.
Both tracks are embedded in a *.mkv container.
Since I need not such a high resolution and prefer smaller video files on my hard disk I want to re-encode it with Avidemux to a lower bitarate and MP3 as audio codec.
Whenever I do this the resulting video is asynchronous.
So sometimes the audio part is approx 9 seconds ahead, other only 4 seconds.
Since I encoded with the same settings 50 other videos the used current Avidemux are correct.
So I am searching for another way to produce a smaller video file.
How can I achieve this?
How do I de-mux the audio part with mkvmerge GUI from mkvtoolnix package?
Have you tried gMKVExtractGUI or mkvcleaver? Then mux back with mkvmergegui (part of mkvtoolnix).
Direct Stream Video - But Keep Audio Codec & Change Bitrate in an MKV file
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 4th Jan 2016, 23:00 -
Issue with Yamb and MP4Box (adding audio-stream to video-stream)
By slax65 in forum Video ConversionReplies: 2Last Post: 21st May 2015, 06:39 -
Intergrating an audio stream into a mkv
By Prozac500 in forum Blu-ray RippingReplies: 1Last Post: 9th Nov 2013, 08:13 -
MKV Demux/Muxing into MP4, No Video Playback
By dunnuck in forum Video ConversionReplies: 6Last Post: 4th May 2013, 22:22 -
Demux audio from ntsc video and mux with pal,audio sync problems
By luis67 in forum AudioReplies: 6Last Post: 17th Nov 2012, 05:43
