  1. Thanh Lư Cường Phát davidvicky's Avatar
    Sep 2016
    Hi,
    I have a 3d demo bluray disc which has different 3d clips which are stored as chapters in one big m2ts file.
    I want to split the file into chapters/clips so that I can independently play each clip from my computer or popcorn 500 player to show off my home theater.
    Can somebody please tell me how to do it.
    thanks
    USA
    I use tsMuxeR GUI to separate .m2ts clips from the BD STREAM folder and output them as .ts files. I get rid of the PGS files if I don't need them.
    Then if I want them smaller, I put them into VidCoder and reduce the size. This may not work with your particular BD file. When you get them to .ts files, you can also edit with something like AVIDemux to split them up.
    But others may have better suggestions.
    And welcome to our forums.
