Results 1 to 18 of 18
    Jul 2008
    Hi -- I have a bunch of footage in ProRes 422. It was Super 8 footage that a place transferred for me, and it's in 29.97, so they duplicated frames (1-2-2 pattern) to match the original 18fps frame rate (contrary to what we were hoping for). (To be clear, not telecined: all the frames are clear single film frames.)
    I want to de-duplicate it to it's native 18fps. I've found this answer for using ffmpeg's mpdecimate filter.
    ...but I want to do this losslessly. Since ProRes is all intra-frame, shouldn't it be possible to de-duplicate it without transcoding? Any tips on how to approach that? Or is ffmpeg smart enough to do that if it's reading in ProRes and writing out ProRes?
    Thanks for thoughts!
    -c
    P.S. here's the footage info:
    $ ffprobe file.mov
    ffprobe version 3.0.7-0ubuntu0.16.10.1 Copyright (c) 2007-2017 the FFmpeg developers
      built with gcc 6.2.0 (Ubuntu 6.2.0-5ubuntu12) 20161005
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'file.mov':
      Metadata:
        major_brand     : qt
        minor_version   : 537199360
        compatible_brands: qt
        creation_time   : 2017-03-31 13:10:28
        com.apple.proapps.logNote: etc
        com.apple.proapps.reel: 001
        com.apple.proapps.scene: Scene 01
        com.apple.proapps.shot:
        com.apple.proapps.angle:
      Duration: 00:11:16.31, start: 0.000000, bitrate: 207087 kb/s
        Stream #0:0(eng): Video: prores (apch / 0x68637061), yuv422p10le(bt709), 1920x1080, 207081 kb/s, SAR 1:1 DAR 16:9, 29.97 fps, 29.97 tbr, 30k tbn, 30k tbc (default)
        Metadata:
          handler_name    : Apple Alias Data Handler
          encoder         : ProRes 422 HQ
          timecode        : 00:00:00;00
        Stream #0:1(eng): Data: none (tmcd / 0x64636D74) (default)
        Metadata:
          reel_name       : time
    Unsupported codec with id 0 for input stream 1
  2. You would have to do it manually specifying where to cut if you use a decimation filter. Because when a filter is applied (ffmpeg or avisynth) , frames are decoded (decompressed to uncompressed 10bit422 YUV for prores HQ) . You can never get back the original prores compression . Recompressing it with prores would be lossy .
    It might be possible if you output a decision list and use that to specify script cuts in stream copy mode (-c:v copy)
    Jul 2008
    Thanks! -- that's what I was afraid of.
    Are you aware of any scripting way I could make it happen? I thought I read about some plugins for NLE's (which I don't own) that allow you to open footage in deduplicated form... I'm using Davinci Resolve... wonder if there's a scripty way I could do it.
    Or a script I could write for Blender? But maybe it's not capable of the no-transcoding cuts, since it probably uses ffmpeg anyway...
    Or if you knew of a relatively simple code library? I'm no C hacker, but if there was e.g. a python or java library for lossless cuts in ProRes I could write a program to do it...
  4. You would need software that can "smart render" prores. So MAC version of PP (PC won't do it), FCP/X, etc... and if you feed it an EDL or AAF it should work ("cuts only" editing will pass through frames untouched) . But the formatting of EDL's and AAF's vary
    In theory ffmpeg could do it too with -vcodec copy -acodec copy , with -t and -ss , and appending the segments with concat demuxer . It doesn't have direct edl input like mplayer .
    There might be some advanced scripting you can use to get it working
    eg. maybe something like this
    https://hackmemory.wordpress.com/2013/04/08/lightning-fast-video-splitting-script/
    Do you really need it back as prores ? It's not a huge quality hit, and there are established workflows for lossless intermediates if you really need that
  5. Possible in vdubFM, it can pass prores without recompression. I don't know if there is a filter to remove exactly the frames you want. Maybe just try "convert to fps".
    Jul 2008
    Interesting -- chop up the original into thousands of single-frame-length prores files, then concatenate them? I'll look further in to that...Since the concat demuxer can work off a text file list, that bodes well. Hopefully specifying the frame by timestamp is accurate enough to work (it apparently goes into microseconds) and hopefully the files themselves stay true to the 122 pattern... otherwise i'm sunk. :-)
    Yeah I'll survive if I can't make it happen (the transfer house may just end up running the film again.) It's family archive stuff, and I just want to preserve best I can for posterity.
    @shekh -- thanks -- good to be clued in to virtualdub filtermod -- the frame rate change looks like it can select every nth frame, but not do patterns, but it's nice to know about.
  7. With luck the pattern may appear automagically, I`d try to just set "18" in the "convert to" field.
    Jul 2008
    It occurs to me that since the file is in 30/1.001 and the super 8 was 18, there's a chance that the duplication may not strictly follow 1-2-2 and might not duplicate a frame now and then to stay in time... i guess there's only one way to find out...
    Jul 2008
    Meaning, VDFM might have been coded to do this under the hood by detecting duplicates or something? Does that maybe seem unlikely? I suppose it'd be easy enough for me to try, and would certainly save time.
  10. No, it does not detect nothing, but it will throw away some frames to make new framerate. This is old feature from VirtualDub.
    Jul 2008
    Some progress... I made a script that uses ffmpeg to run mpdecimate and just log the results (without writing a file):
    ffmpeg -i file.mov -vf mpdecimate=max=1 -loglevel debug -f null - > mpdecimate.txt 2>&1
    I then parse out the time stamps of "keep" frames from that log, and use ffmpeg to generate single-frame .mov files for each "keep" frame:
    cat mpdecimate.txt | grep Parsed | grep keep | sed -r 's/^.*pts_time:(.*) drop.*/\1/' > ts.txt
    cat ts.txt | awk "{printf \"ffmpeg -ss %s -t $flen -i file.mov -vcodec copy -acodec copy %08d.mov\n\",\$1,f;f++}" > ffmpeg.txt
    source ffmpeg.txt
    (where flen is the calculated time length of a single frame, e.g. 1/(30/1.001))
    That generates (and runs) a file that has many commands like this:
    ffmpeg -ss 43.0096 -t 0.033366666666666 -i file.mov -vcodec copy -acodec copy 00000768.mov
    I then concatenate the resulting single-frame mov files with this (I'm leaving out a lot of the script; the original .mov is not in this same directory):
    /bin/ls -1 *.mov | sed -r "s/(.*)/file '\1'/" > segmentfiles.txt
    ffmpeg -f concat -i segmentfiles.txt -c copy file_dedup.mov
    This almost works. :-)
    It seems fine for the first few seconds, and then starts to slow down: duplicate frames are generated, frames skip back in time, etc. It seems apparent that the -ss and -t combo is perhaps not precise enough to target an individual frame (or that the log file mpdecimate is generating is not accurate, or that I'm misinterpreting it somehow.) Any tips on that?
    Also, the generated result file is still 29.97, and I'm not having great success switching it to 18. The framerate changing stuff seems to require transcoding. The more elaborate route of changing timescale intimidated me a bit, and I wasn't sure if it was wise for my case. Any ideas on that?
    Thanks! I appreciate the time.
    Jul 2008
    Hey, further clues!
    If I move -ss and -t after the initial -i, it targets the frames more accurately. Seems odd to me, since they're all keyframes, and I thought -ss before -i meant that it found the nearest keyframe to that point in time. Maybe a bug? Takes a little longer with -ss after the -i, but not too bad. Edit: I thought it took longer; maybe not, since it's ProRes and shouldn't really matter? Anyway...
    Still some duplicated frames in the output, though... working on tweaking mpdecimate now...
  13. Did you try playing with the threshold values ?
    Is there audio ?
    There are other non ffmpeg methods that are probably more accurate for smart decimation
    For Quicktime MOV it is difficult to manipulate the timecodes and keep it "legal" for compatibility . There are 1 or more timecode tracks and open source tools have difficulty editing. You can manipulate timecodes with other containers like MP4 with tools like lsmash works, mp4fpsmod, but for MOV you basically need Mac tools like FCP / FCPX
    https://developer.apple.com/library/content/documentation/QuickTime/RM/MovieBasics/MTE...diaHandle.html
    https://documentation.apple.com/en/finalcutpro/usermanual/index.html#chapter=51%26sect...3%26tasks=true
    Jul 2008
    I think I got it -- after tweaking mpdecimate, it still seemed to be a frame targeting issue... ffmpeg's -ss and -t aren't grabbing exactly the right frame all the time... so I just nudged back each frame timestamp 10% of a frame length to make sure it wasn't falling near a frame boundary, and it worked perfectly. ffmpeg must just be going to the next frame, rather than the nearest, in either -ss mode (meaning, before or after -i).
    So the only remaining problem is the frame rate... thoughts?
    Jul 2008
    Yep, thanks -- in fact I've switched over to not using hi at all, because even between duplicate frames there frequently seems to be at least one 8x8 block that crosses it. I'm currently using a lower "lo" threshold (64*3) and frac of .4. Might need tweaking per file, I don't know...
    Is there audio ?
    No, which is nice.
    Interesting -- any names/links?
    For Quicktime MOV it is difficult to manipulate the timecodes and keep it "legal" for compatibility.
    That's disappointing... thanks for the info. I know there is a ton going on under the hood of video codecs, but the difficulty in changing framerates really comes as a surprise. Naively one would think it would just involve tweaking a header value.
    I'll post the script when it's done in case anyone else is interested.
  16. For decimation there are a bunch of avisynth methods . If you have no audio it's one thing less to worry about and more approaches that you could use
    http://avisynth.nl/index.php/External_filters#Duplicate_Frame_Detectors
    This isn't the full list, and many of the decimation filters have metrics output
    http://avisynth.nl/index.php/External_filters#IVTC_.26_Decimation
    They definitely work , people in similar situations as you use avisynth commonly for the decimation part . The QT/Prores "smart render" cuts is a new twist however. I'm interested if you can post the script(s)
    AFAIK only FCP/FCPX / cinema tools can do framerate changes to MOV/quicktime without re-encoding reliably. Blame Apple.
    You can do it easily to other formats (just change header, or mux in new timecode track) ; and MOV is just a MP4 derivative you would think the same MP4 based tools for TC manipulation would work, but they don't.
    Jul 2008
    Ok, I made a blog post about the bash script, which I called "lld"; link to the script is on that page. I'd appreciate any corrections to my thinking on it.
    Thanks again for the help!
    http://lacinato.com/cm/blog/26-lld-losslessly-decimate-de-duplicate-on-linux-prores-etc
  18. Thanks for the follow up post & script
