Please consider supporting us by disabling your ad blocker or buy PlayOn and record Netflix! :)
  1. Hi,
    I'm trying to figure out why when I click record and then clcik stop in Open Broadcaster Software that when I play that recording back it displays no video and the only audio is a loud static noise.
    I see the video counter numbers increase while recording so I know it's recording and the file on the hard drive for that recording is fairly large.
    I Googled for an answer but videos I find appear so tiny when I view them.
    I've enlarged the screen doing Ctrl + but that just makes the screen larger and the video blurry.
    I surmise the content creator and/or YouTube applies some kind of compression software to compress the video.
    https://www.youtube.com/watch?v=QjEWAJ3d-jw
    Any idea how to enlarge what you see IN the video?
    Thank you so much.
  2. Download videos locally to HDD - 1920x1080 should be OK when watched.
  3. Originally Posted by eager to learn View Post
    For the video, set up two sources: a "display capture" and a "game capture," where the latter is set to "capture any fullscreen application." Place the game capture above the display capture in the source list. Start recording: your desktop is captured. When an application (game, video player) goes full screen it cannot be captured as "desktop" but it will now be recorded by the "game" source, after a short switching delay.
    For the audio, you need to add an "audio input" source, set to "stereo mix" (the name can vary - it's also known as "what u hear"). Whatever source you have now is wrong - mute it.
    Hopefully this quick description will give you enough to get started. Google a term and you'll likely find a tutorial on it.
  4. Hi raffriff42,
    How do I do waht tyour suggesting using Firefox's add-on downloader?
    In OBS, when I click record I get no video and only a loud buzzing sound.
    Thanks.
  5. You asked about OBS and that's the question I answered.
  6. This is really confusing...I am a newbie here. I have seen some brilliant questions here. Hope I will get answers for all my doubts regarding video uploading, editing etc.
  7. Originally Posted by eager to learn View Post
    Click on the gear tool and select Quality -> 1080p, or 720p. Then go full screen.
