is the any of his option which affects the lines that he chooses ?
in default it chooses all the lines
say i only want is to affect the clear and distinctive black lines and not the ones that are like shadows
here is an exmaple.
http://screenshotcomparison.com/comparison/207139
notice how the shdowed edges are affected too.
say i want it only to affect the black lines
is there an "tweak" in the Hysteria filter? i wast able to find one
Use an editor like avspmod, and you can adjust the values to "see" what is happening. That's how you learn what the settings do
Code:lowthresh = Default(lowthresh, 6) highthresh = Default(highthresh, 20) showmask = Default(showmask, false) strength = Default(strength, 1.0) str = String(strength) usemask = Default(usemask, true) luma_cap = Default(luma_cap, 191) lc = String(luma_cap) maxchg = Default(maxchg, 255) lim = String(maxchg) minchg = Default(minchg, 0) thr = String(minchg)
VirtualDub: "AVI Import Filter error: (Unknown) 80040154"
By Xavier in forum Newbie / General discussionsReplies: 11Last Post: 15th Dec 2021, 18:49 -
cant make "dehalo_alpha" filter work
By zanzar in forum Newbie / General discussionsReplies: 0Last Post: 6th Feb 2016, 10:49 -
FFMpeg : Use the "volume" filter for Preamp Equalizer setting ?
By alexander121 in forum AudioReplies: 0Last Post: 25th Jul 2015, 08:38 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
Avisynth "look back" filter/command?
By lordsmurf in forum RestorationReplies: 1Last Post: 27th Jan 2014, 02:01
