Theres a CTRL+I shortcut for this app that displays time as runningtime/total time which i like . Lets say you've watched 5 mins of 40min file it will say 05:00/40:00. Something happened and now when i press it tells me the remaining and instead wil now show -35:00/40:00 telling me theres 35 mins left. I prefered it as it was. I'm searching inside the preferces and googling and cannot find why it happened and how to change it back
AnonymousGuest
Hello
Thanks for this thread as I was annoyed by this problem and it helped.
Just to clarify, for me right click worked. But right clicking on the timecode along your timeline display at the bottom right corner 00:00:00/00:0000
Not in the top left in case you have info display enabled and its showing there. Thanks again
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 18:54 -
Time and volume info on the upper left corner on MPC
By miba54 in forum Software PlayingReplies: 2Last Post: 24th Nov 2014, 14:46 -
MPC-BE: how to display datacode (PGS-Subtitle) like in MPC-HC
By flashandpan007 in forum Software PlayingReplies: 0Last Post: 29th Apr 2013, 14:14 -
Always +125% video/Frame/Zoom size MPC-HC/MPC-BE?
By tigerb in forum Newbie / General discussionsReplies: 6Last Post: 8th Mar 2013, 16:57 -
Are there canon third party batteries showing battery life remaining
By sean00 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 22nd Feb 2013, 17:07
