When I try to convert some AVI's I download to vcd mpeg it just converts with a black screen. I hav ehte correct codec and they play perfectly. I need your help!
I had the same problem. I reinstalled the DivX-codec from www.divx.com and the problem was history.
I could (too) watch the movie in Media Player or The Playa or whatever, but the screen was black in virtualdub and tmpgenc.
Hope this helps.
8) Raunso -
If you are using 2-pass VBR, which is what it sounds like, then that is what it is supposed to do. The first 50% of encoding, which is the first pass, will be just a black screen!!! After 50%, the second pass will start, and you should start seeing frames!!!
HELP! Black screen/Blue Screen problem
By will7370 in forum ComputerReplies: 2Last Post: 1st Apr 2012, 09:30 -
black screen....
By ray316 in forum ComputerReplies: 3Last Post: 8th May 2010, 06:52 -
Black Screen?
By Hal05154 in forum Video Streaming DownloadingReplies: 0Last Post: 11th Jul 2009, 06:57 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 11:16
