Hello,
I'm using the Aiseesoft Ultimate video converter for trimming/joining my DVB records. Generally speaking, I merge the two or more segments of the .vob files of my recorder and then I trim the resulting file.
I have noticed that when I play the point where the two segments of the video are joint, there is a little interrupt that breaks the smooth of the video, making it of poor general quality.
I have tried all of the processes available with that application and I have found that the only one to reduce the number of those little visible interrupts is the one you may see in the video I recorded the process I use in order to show you what I mean: https://youtu.be/WKQBDamLRsE
I wonder what is the best way or free application for fixing or making the process above without any issue.
Thank you.
Joint MP4 video does not play 2nd part
By virusvoodoo in forum EditingReplies: 1Last Post: 15th Nov 2015, 05:14 -
Trying to fix video recording - 30fps to 25fps. Still not playing smoothly.
By Phat J in forum Video ConversionReplies: 8Last Post: 9th Nov 2015, 18:52 -
How to fix this subtitle issue on VLC?
By tiulauleejung in forum SubtitleReplies: 2Last Post: 27th Oct 2014, 10:34 -
Issue playing video with MPC -HC x64
By Dre9872 in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2014, 11:20 -
How to fix Video Recorded via iphone 4 that rotated 90 degrees when playing
By spiderMan007 in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2013, 11:00
