Results 1 to 23 of 23
    Sep 2014
    Rome
    hi
    i have 2 questions
    my first question is :
    1)
    i have bought motionarray transition pack , there are lots of mov files inside and a mp4 tutorial video file (i can play it)
    but i can't import these mov files inside premiere cc 2017 & 2015 , i can't even open with avidemux 64bit last version
    my operation system is windows 10 pro 64bit
    i tried to rename these mov files to avi or mp4 without luck
    i used mediainfo to check these files and i get this
    General
    Complete name                            : L:\premiere\01. Transitions\Transition 84.mov
    Format profile                           : QuickTime
    Codec ID                                 : qt   2005.03 (qt  )
    File size                                : 3.81 MiB
    Duration                                 : 1 s 968 ms
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 16.3 Mb/s
    Encoded date                             : UTC 2016-12-23 13:29:39
    Tagged date                              : UTC 2016-12-24 11:31:44
    Writing library                          : Apple QuickTime
    Video
    Format                                   : PNG
    Format/Info                              : Portable Network Graphic
    Codec ID                                 : png
    Bit rate mode                            : Variable
    Bit rate                                 : 16.2 Mb/s
    Width                                    : 4 096 pixels
    Height                                   : 2 304 pixels
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (30000/1001) FPS
    Compression mode                         : Lossless
    Bits/(Pixel*Frame)                       : 0.057
    Stream size                              : 3.81 MiB (100%)
    Language                                 : English
    Encoded date                             : UTC 2016-12-23 13:28:34
    Tagged date                              : UTC 2016-12-23 13:29:39
    is there a reason why i can 't open them?
    my second question is
    2)
    are there 100% free transition and title preset for premiere cc ?
    i have googled a lot but i have found lots of unless site where i can't download anything
    thanks
    Happy Easter
    and i could upload a mov file if the forum rules allows me
  2. Do you have the QuickTime codec installed on your pc? Have you managed to play these files outside of premier using QuickTime?
    Sent from my iPhone using Tapatalk
  3. 2 question: you might be able to get some free presets off VideoHive.com, there will be other that will charge a small fee, big time saver if you are under a deadline and there will be lots of options and styles for you to choose from [emoji106]
    Sep 2014
    Rome
    hi
    yes i have , maybe it's outdated , does quicktime alternative work too
  5. I would install QuickTime for sure, your on Premier CC so that's fairly new. You wouldnt have to purchase QuickTime Pro for this to work as it's only a MPEG 4 file which is native to QuickTime. Hope that works for you.
  6. Assuming you are on a PC, not Mac,
    Scroll down in this link (http://avid.force.com/pkb/articles/how_to/QuickTime-Support-and-Security-on-Windows) to the section titled "Temporary solution." You want to install Quicktime Essentials but not the player.
    It's for Avid, but applies to Premiere as well.
    Sep 2014
    Rome
    hi
    thanks
    I will install it and i will post if it work ,yeas i'm under windows
    Sep 2014
    Rome
    Hi
    i have installed but i can't import in premiere cc
  9. Did you open the included project in PP or just the individual mov files?
    There are internal dependencies.
  10. Did you try "regular" quicktime install? Including the player ?
    Alternatively, you can convert to another compatible format
    Sep 2014
    Rome
    Hi
    no, i haven't install the player , may i ask you a question? are you running windows Operation system)
    thanks
    hi
    i have dragged to my project palete , and i get the error , i tried to import error
    thanks
  12. Originally Posted by rama View Post
    Hi
    thanks
    Windows; I have QT Pro installed, but you shouldn't need the pro version
    QT comes with all the necessary codecs . When you use purchase transitions, alpha mattes, etc... the most common distribution format is animation codec in MOV , the 2nd most common is PNG in MOV (that is what you have there)
    QT is officially discontinued on windows (supposedly a security risk), but many people still use it .
  13. Originally Posted by rama View Post
    thanks
    What happens if you just double-click the .prproj file?
    Sep 2014
    Rome
    Hi
    thanks
    Hi
    it's work under w8.1 and 7
    weird it doesn't work under w10 pro
  15. Originally Posted by rama View Post
    win10 does more "security" things , since QT is officially discontinued that's probably why . I don't have any machines with win10 yet, but there might be some workaround the QT issue you'd have to use google and search
    Or you can re-encode to a compatible format, but probably smarter/easier to use w7/8
    Sep 2014
    Rome
    hi
    I agree , there are a lot of files to transcode and i don't know which tool could i use
    i guess i will try to restore a windows 10 old image and i try it
    thanks
  17. Originally Posted by rama View Post
    It's possible with ffmpeg batch, or some gui for ffmpeg like ffqueue
    A suitable replacement format would be UT Video Codec, with RGBA for alpha mattes (or just RGB for luma mattes)
    Or you can try searching for workarounds for QT/ Win10
    (I don't know if these work, use at your own risk, but the official microsoft reply looks promising)
    eg
    https://tommynation.com/install-quicktime-windows-10/
    http://www.laptopmag.com/articles/install-quicktime-windows-10
    https://answers.microsoft.com/en-us/windows/forum/windows_10-windows_install/how-to-in...7-1cd18b255a9b
  18. Member
    Sep 2014
    Rome
    eg
    Hi Pal
    thanks a lot
    seems that the last tips works but it's insane i have to install AppleApplicationSupport.msi & AppleSoftwareUpdate.msi and run AppleSoftwareUpdate and install quicktime
    hope the new w10 update won't mess up it
    and
    it doesn't complete the job , it finished always with an error
    may i ask you a question ? what operation system do you run?
    thanks a lot !! really appreciate your help
  19. I think you have to setup the preset in ffqueue . Or maybe tencoder . They might have presets already
    or just use a batch file
    0) you need to install "ut video codec" in order to use it in Adobe
    1) open a file in notepad in the same folder of MOV files to be converted (for now, just test 1 or 2 at first) , copy and paste the following, save it, rename extension from .txt to .bat . e.g. "batch.txt" becomes "batch.bat"
    for %%a in ("*.mov") do ffmpeg -i "%%a" -c:v utvideo -pix_fmt rgba -an "%%~na.avi"
    pause
    2) place a copy of ffmpeg.exe into the folder
    3) double click the batch file
  20. Member ricardouk's Avatar
    Mar 2005
    Portugal
    hi
    I've done the same thing...it works fine on windows10 (trial version premiere 2017) without any 3rd party codec packs, its weird that it says "png" in the mediainfo report. If you use motionarray there's free presets for premiere titles and transitions...which leads me to ask... did you "bought it"? If you did talk to the support...
    I love it when a plan comes together!
  21. I had no problem with the packages, provided I opened the project file they came with. The .png codec files appear to be graphics that are dependent on functions within Premiere.
    Rama, I asked earlier if you tried to open the project files and you never responded.
  22. Member
    Sep 2014
    Rome
    hi
    yes I have responded #11
    yes i have tried to open the project but got always the same error
    thanks
  23. Member
    Sep 2014
    Rome
    hi
    can you explain it? what have you done rename the files ?
    i have contact them for first they told me to install the new version of quicktime and in case of issue to rename them ,nothing else
    thanks
    Edit about windows 10 I tried another way , i download QuickTime Alternative 3.2.2 and i have installed with this settings
    and it works perfectly !! without
    i wanted to share for the other users!
