Since zones don't work with 10-bit in x264, I decided to encode credits at lower bitrate and then join the two up but it's not working. I used the same encoding settings for both except the lower bitrate. Why can't I join them?
Results 1 to 12 of 12
General
Unique ID : 187141895354917483386712576831841563745 (0x8CCA37CF975F3F9599D76AA21ABEF461)
Complete name : M:\sav.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 590 KiB
Duration : 10 s 0 ms
Overall bit rate : 484 kb/s
Encoded date : UTC 2017-04-16 00:33:15
Writing application : mkvmerge v10.0.0 ('To Drown In You') 32bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5
Video
Format : AVC
Format profile : High 10@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 477 kb/s
Nominal bit rate : 1 067 kb/s
Width : 704 pixels
Height : 576 pixels
Display aspect ratio : 1.222
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.047
Stream size : 583 KiB (99%)
Writing library : x264 core 148 r2744 b97ae06
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=11 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=250 / rc=2pass / mbtree=1 / bitrate=1067 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
Language : English
Default : Yes
Forced : No
General
Complete name : M:\SavCds.mkv
Format : Matroska
Format version : Version 2
File size : 2.75 MiB
Duration : 3 min 8 s
Overall bit rate : 122 kb/s
Writing application : x264 r2744 b97ae06
Writing library : Haali Matroska Writer b0
IsTruncated : Yes
Video
Format : AVC
Bit rate : 120 kb/s
Width : 704 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.012
Stream size : 2.69 MiB (98%)
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=11 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=250 / rc=2pass / mbtree=1 / bitrate=120 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:1.00
Language : English
Default : Yes
Forced : No -
AnonymousGuest
Two things:
-- (not so important) you forgot to define the pixel aspect ratio
-- (important) you forgot to use the --stitchable switch
Anyway: I could demux the elementary streams with ffmpeg and then I concatenated them with the olde and goode copy /b.
Then I remuxed the full-length video with mkvmerge. The new MKV file plays fine in both MPlayer and MPC-HC. -
What? Since when?Since zones don't work with 10-bit in x264
mkvmerge complains with:Why can't I join them?
This happens because you didn't use '--stitchable' when encoding the clips.The track number 0 from the file '... sav.mkv' can probably not be appended correctly to the track number 0 from the file ' ... SavCds.mkv': The codec's private data does not match (lengths: 43 and 44). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file.
=> x264 is optimizing the headers of the video content which makes them incompatible.Code:--stitchable Don't optimize headers based on video content Ensures ability to recombine a segmented encode
(took to long: Marsia Mariner also posted a workaround.)users currently on my ignore list: deadrats, Stears555, marcorocchini -
-> Sounds like a bug in MeGui, would be new to me that this is a general bug in x264.Well, it didn't work for me with megui.
-> luck is with the ignorantI've joined MKVs before this way without problems and I don't remember having to use --stichable, this is the first time I hear of such a setting.
The point is that header optimization might result in different sized headers, but it doesn't have to. So yes, you were simply lucky to haven't run into this problem before.
what is the exact ffmpeg commandline?andCode:ffmpeg -i "path to input .mkv" -vcodec copy -an -bsf:v h264_mp4toannexb "path to output .264"
should be prototypes of calls Marsia Mariner referred to.Code:copy /b "path to part1.264" + "path to part2.264" + "path to part3.264" "path to output .264"
Cu SelurLast edited by Selur; 16th Apr 2017 at 04:12.
No scripts, just two command line calls.
1st call is the ffmpeg call meant to extract the raw .264 stream from a .mkv file. (see: https://www.ffmpeg.org/ffmpeg-all.html)
2nd script shows how to concatenate multiple raw streams (in my example case three) into on file raw .264 output file. If you only have two files use:
if you have 4 use:Code:copy /b "path to part1.264" + "path to part2.264" "path to output .264"
see: bottom of https://support.microsoft.com/en-us/help/240268/copy,-xcopy,-and-move-overwrite-functi...ges-in-windowsCode:copy /b "path to part1.264" + "path to part2.264" + "path to part3.264" + "path to part4.264" "path to output .264"
Yes.Wait a minute, this copy function is without ffmpeg?
Yes.So it's literally joining the files bit-by-bit?
They are not, but that doesn't mean in some cases one can't create slightly 'broken' streams and rely on other tools to handle the streams as they should.I never knew H264 streams were that simple.
-> The proper solution is to use '--stitchable' using those two options is a workaround that should work assuming the streams are compatible and just the headers are 'off'.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Join videos without reencoding!
By VHGNM in forum Video ConversionReplies: 4Last Post: 16th Mar 2017, 11:02 -
Join many videos to 1 file?
By HOK1N in forum EditingReplies: 1Last Post: 22nd Aug 2016, 09:16 -
join videos
By randomperson in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2016, 03:26 -
Append / Join MP4 Videos
By darkw1zard in forum Video ConversionReplies: 7Last Post: 22nd Feb 2014, 00:02 -
Need to join two videos with FFMPEG
By wolfox in forum EditingReplies: 1Last Post: 5th Oct 2012, 17:46
