I have an EXE that opens a standalone player (exported from a DVR) and has some video embedded in it. I'd like to extract the raw video so I don't have to play it in their player.
It may be possible if they used standard compression methods, eg., you could right click the file and select extract ...
AnonymousGuest
Well, it depends a lot on the .EXE itself. As davexnet said, MAYBE you can extract the contents with 7-Zip or with UniExtract (or with something else).
But if the .exe uses non-standard "packaging" OR/AND is encrypted, then capturing the video during playback will be the only workaround.
Extracting video segments from ISO
By vikasa in forum Video ConversionReplies: 4Last Post: 15th Apr 2016, 10:02 -
Extracting the video file from an .htm
By Enthus in forum Newbie / General discussionsReplies: 20Last Post: 31st Jan 2016, 00:36 -
Extracting thief's face from video
By anonan in forum RestorationReplies: 6Last Post: 28th Oct 2015, 09:50 -
Extracting MMS Video Stream - Cannot find direct video link
By childofsai in forum Video Streaming DownloadingReplies: 6Last Post: 21st Feb 2013, 17:18 -
Extracting the video from a FLV
By headless chicken in forum Video ConversionReplies: 4Last Post: 10th Dec 2012, 07:24
