Need help. I ran into trouble trying to download the new Kodi release. my 4K MX III was not compatible. I erased the old versions, now I'm unable to download any KODI. Any advise? , Thank you.
You can download Kodi 16.1 Jarvis for ARM processors here: http://www.apkmirror.com/apk/xbmc-foundation/kodi/kodi-16-1-release/kodi-16-1-3-androi...-apk-download/
(I'm assuming you had 16.1 before, and tried to install 17 Krypton)
Put it on an SD card or USB stick and plug it into your TV box, then install this apk using the APK installer you hopefully have on your box.
Hopefully this helps
What happened to Kodi?
By flashandpan007 in forum Off topicReplies: 6Last Post: 2nd Apr 2017, 12:44 -
Raspberry Pi - KODI - .ts link
By kirkmc in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2017, 03:01 -
convert DVD to play on Kodi
By SingSing in forum Video ConversionReplies: 4Last Post: 4th Jan 2017, 01:10 -
Re: Having issues with kodi 15.2 and MXBox
By Richiemxbox in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2016, 09:23 -
kodi xbmc pseudtv lite
By bermuda in forum Newbie / General discussionsReplies: 2Last Post: 4th Mar 2015, 16:26
