hello everybody
i need a program that encode a movie with a SRT subtitle file (external) hardcoded type and need change font subtitle to my selection.
must say. i try a handbreak - xmedia recode. both are perfect, but i cant change font subtitle for hardcoding.
thanks.
Results 1 to 13 of 13
if convert to graphical sub. result not good.
i want a program that can change font for subs.
recently i used ripbot. and in avisynth script cant create a font for subtitle section
--this is a sample---
#MT
#VideoSource
video=DirectShowSource("C:\Users\Hello!\Downloads\ Video\Annabelle__Creation_Trailer_1_(2017)___Movie clips_Trailers-[1080p].mp4",audio=false,fps=23.976).ConvertToYV12(matrix ="rec709")
#Levels
#Colours
#Denoise
#Subtitles
Loadplugin("C:\Users\Hello!\Downloads\Compressed\R ipBot264v1.19.6\Tools\AviSynth plugins\VSFilter\VSFilter.dll")
video=TextSub(video,"C:\Temp\RipBot264temp\job1\To Steal from a Thief (2016).srt",-1)
#AudioSource
Import("C:\Temp\RipBot264temp\job1\job1_a1.avs")
#Triming
can anybody help me? -
ASS/SSA is not a bitmap format. You can convert srt to ASS using Subtitle Edit or Aegisub, then mux into your video using mkvmerge and then burn-in using HandBrake. That's what manono meant.
Alternatively, there are solutions for Avisynth:
https://forum.doom9.org/showthread.php?t=174423
The TextSub() filter you used in your script example can also read ASS subtitles. It can also use ASS style to override.
http://avisynth.org.ru/docs/english/externalfilters/vsfilter.htm -
I already helped you. I don't (and won't) use Handbrake but, apparently, it can open SSA subtitles on its own:
Subtitles (VobSub, Closed Captions CEA-608, SSA, SRT)
Or, as sneaker mentioned, both SSA and ASS subs can be used in the AviSynth script:
video=TextSub(video,"C:\Temp\RipBot264temp\job1\To Steal from a Thief (2016).ass",-1)
All you have to do is to convert your SRT subs to SSA or ASS. I usually use Subtitle Resynch which is included in the VOBSub package, although there are several other ways to convert from SRT. Then all you have to do is choose your font by (maybe) opening the sub file in Notepad or by using a subtitle program to choose the font. -
For Handbrake to hardcode ASS/SSA embed (mux) the subtitle into the video with MKVToolnix.
https://handbrake.fr/docs/en/latest/advanced/subtitles.html -
ffdshow (using its VirtualDub plugin) can apply an overall style, including font, to an SRT subtitle. Load the VirtualDub plugin and burn your subtitles.
https://www.google.com/search?q=ffdshow+virtualdub+subtitles -
Good to know. Maybe that link page should be updated.
No one really uses SSA anymore, it's extremely old. -
thanks all guys.
but how can work with vobsub?
i opened a srt file and dont know how can save s ssa file.
http://uupload.ir/files/35fa_photo_2017-04-15_19-08-14.jpg -
Sownload and Install Subtitle Edit
Load srt file to Subtitle Edit
Change Font
Save as SSA
example
[Script Info]
Title: <untitled>
Original Script: <unknown>
ScriptType: v4.00
Collisions: Normal
Timer: 100.0000
[V4 Styles]
Format: Name, Fontname, Fontsize, PrimaryColour, SecondaryColour, TertiaryColour, BackColour, Bold, Italic, BorderStyle, Outline, Shadow, Alignment, MarginL, MarginR, MarginV, AlphaLevel, Encoding
Style: Default,MixComic,18,16777215,16711680,65280,0,0,0, 1,2,3,2,5,5,5,0,1
[Events]
Format: Marked, Start, End, Style, Name, MarginL, MarginR, MarginV, Effect, Text
Dialogue: Marked=0,0:00:26.32,0:00:28.96,*Default,NTP,0000,0 000,0000,!Effect,It's another hot, sunny day today here\Nin Southern California.
Dialogue: Marked=0,0:00:29.04,0:00:31.15,*Default,NTP,0000,0 000,0000,!Effect,Temperature is 84\Nfor downtown Los Angeles,
Dialogue: Marked=0,0:00:31.24,0:00:32.75,*Default,NTP,0000,0 000,0000,!Effect,overnight lows of 75.
Dialogue: Marked=0,0:01:13.36,0:01:14.99,*Default,NTP,0000,0 000,0000,!Effect,I think about that day
Dialogue: Marked=0,0:01:15.08,0:01:18.71,*Default,NTP,0000,0 000,0000,!Effect,I left him at a Greyhound station\Nwest of Santa Fe
Dialogue: Marked=0,0:01:18.80,0:01:22.43,*Default,NTP,0000,0 000,0000,!Effect,We were 17, but he was sweet\Nand it was true
Dialogue: Marked=0,0:01:22.56,0:01:26.11,*Default,NTP,0000,0 000,0000,!Effect,Still, I knew what I had to do -
thanks. its work.
this is before you help me
http://uupload.ir/files/6pkp_snapshot20170415193153.bmp.jpg
and it after it
http://uupload.ir/files/8unx_annabelle_creation_trailer_1_(2017)_movieclips_trailers-[...;19-31-11].jpg
A software to hardcode subs with font options (changing color)?
By exwoll in forum SubtitleReplies: 11Last Post: 8th Feb 2016, 12:18 -
encode review : 10h43 for 93 sec clip on old vista
By smartel in forum Newbie / General discussionsReplies: 22Last Post: 3rd Jan 2015, 18:53 -
How to hardcode subtitles?
By kdezfoli96 in forum SubtitleReplies: 9Last Post: 7th Apr 2013, 10:17 -
Encode 50p clip
By kartola in forum Video ConversionReplies: 10Last Post: 1st Dec 2012, 04:17 -
Trying to encode a clip to XviD to join another using VirtualDub ...
By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 02:08
