Hello
I have put the same video through both Handbrake and Any Video Converter for the purpose of adding Subtitles and ability to play on DVD player.
Prefer Handbrake as subtitles can be hard (burned in) or soft (switchable on or off)
The conversion runs OK through both programs but the Handbrake version now has problems with the video breaking up.
Wondering if there are settings in Handbrake that may stop this happening
Following link is to folder with 3 small video clips
m2ts is the original , mkv is the handbrake (with problems) and mp4 is the AVC version (no problems)
The picture breaks up when the character stands up from the sofa
I have also used mp4 through Handbrake and problem remains
As always any advice from you guys will be greatly appreciatedHTML Code:https://www.dropbox.com/sh/63r0rtqj26vto2e/AAAI75R504Pu9H8RpmRaD9rZa?dl=0
Rob
ffmpeg complains at that point:
ffmpeg can handle this error but it seems HandBrake does something special which results in a visible problem. Report to HandBrake developers.[h264 @ 0000000000436120] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one
[h264 @ 0000000004b0c700] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one
https://github.com/HandBrake/HandBrake/issues
A workaround would be to use HW decoding but DXVA got removed at 1.0 because it was too buggy. I believe QuickSync decoding is activated by default so I assume your PC doesn't have it. But you can check in settings to be sure. (Requirements are listed there.)
Video after Handbrake is a disaster
By deanna1ynne in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2016, 22:12 -
upsize a video in handbrake
By mrjayviper in forum Video ConversionReplies: 11Last Post: 17th May 2016, 01:02 -
Audio pitch after video is convert using handbrake or video coder
By Freelife2345 in forum AudioReplies: 3Last Post: 9th May 2016, 03:33 -
Scrambled Video from Handbrake
By prezzacc in forum Newbie / General discussionsReplies: 11Last Post: 19th Apr 2015, 16:48 -
Wondershare Video Converter Ultimate vs WonderFox HD Video Converter Factor
By zzzk in forum Video ConversionReplies: 1Last Post: 3rd Jan 2014, 17:25
