  1. I want to backup my DVD library, some of which seems to be going bad, and I want to convert them to ISO, to keep all the features. A few years back I remember converting DVD to ISO with some free piece of software, but can't remember what it was.
    So how do I rip a DVD into an ISO?
    By the way, I now have Windows 10 on all my PC's. Don't know if that's an issue, but figured it's worth mentioning. (Though I can easily get an older OS installed.)
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I really can't remember any decrypting software that didn't have that option "somewhere" in the options.
  3. Thanks. DVD Shrink seems to be doing the job so far. Many of my DVD's are very old, so I think it should have no problem with them. If some fail I'll look for something else.
  4. Member leghorn's Avatar
    Apr 2007
    Germany
    CloneDVD has an option to save your data to ISO. It's not freeware though. Also you might need a decrypter, e.g. AnyDVD.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
  5. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    I still use DVDShrink but, have to rip disk with AnyDVD first, like 95%+ of the time. AnyDVD = VOB (folders) or iso, but whole disk. I use Shrink for 'movie only', iso or folders.
    I allus have prefered iso's, , , ,
    -c-
    Yes, no, maybe, I don't know, Can you repeat the question?
