So I have a SAMSUNG SE-506 SE-506CB/RSBDE and it writes mkv files and BDMV perfectly but any time I go to copy a mpeg4 or xvid with either nero or imgburn it fails and I have no clue why. any help would be much appreciated as I am clueless at this point
here is my log for the failed burn: ; //**********************************\ ; ImgBurn Version 2.5.8.0 - Log ; Thursday, 13 April 2017, 00:08:18 ; \**********************************// ; ; I 00:00:29 ImgBurn Version 2.5.8.0 started! I 00:00:29 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200) I 00:00:29 Total Physical Memory: 33,504,204 KiB - Available: 26,395,196 KiB I 00:00:29 Initialising SPTI... I 00:00:29 Searching for SCSI / ATAPI devices... I 00:00:29 -> Drive 1 - Info: DiscSoft Virtual 1.0 (L(Virtual) I 00:00:29 -> Drive 2 - Info: DiscSoft Virtual 1.0 (K
(Virtual) I 00:00:29 -> Drive 3 - Info: TSSTcorp BDDVDW SE-506CB TS02 (H
(USB 2.0) I 00:00:29 -> Drive 4 - Info: DiscSoft Virtual 1.0 (J
(Virtual) I 00:00:30 -> Drive 5 - Info: DiscSoft Virtual 1.0 (N
(Virtual) I 00:00:30 -> Drive 6 - Info: DiscSoft Virtual 1.0 (O
(Virtual) I 00:00:30 Found 5 BD-ROM XLs and 1 BD-RE XL! I 00:01:02 Operation Started! I 00:01:02 Building Image Tree... I 00:01:03 Calculating Totals... I 00:01:03 Preparing Image... I 00:01:03 Contents: 26 Files, 1 Folder I 00:01:03 Content Type: Data I 00:01:03 Data Type: MODE1/2048 I 00:01:03 File System(s): UDF (2.50) I 00:01:03 Volume Label: [Not Configured] I 00:01:03 Size: 30,931,460,248 bytes I 00:01:03 Sectors: 15,103,265 I 00:01:03 Image Size: 30,932,533,248 bytes I 00:01:03 Image Sectors: 15,103,776 I 00:01:03 Operation Successfully Completed! - Duration: 00:00:00 I 00:01:47 Operation Started! I 00:01:47 Building Image Tree... I 00:01:47 Calculating Totals... I 00:01:47 Preparing Image... I 00:01:47 Contents: 26 Files, 1 Folder I 00:01:47 Content Type: Data I 00:01:47 Data Type: MODE1/2048 I 00:01:47 File System(s): UDF (2.50) I 00:01:47 Volume Label: MarvelsDaredevil_s01&02 I 00:01:47 Size: 30,931,460,248 bytes I 00:01:47 Sectors: 15,103,265 I 00:01:47 Image Size: 30,932,533,248 bytes I 00:01:47 Image Sectors: 15,103,776 I 00:01:52 Operation Successfully Completed! - Duration: 00:00:05 I 00:01:52 Operation Started! I 00:01:52 Source File: -==//[BUILD IMAGE]/\==- I 00:01:52 Source File Sectors: 15,103,776 (MODE1/2048) I 00:01:52 Source File Size: 30,932,533,248 bytes I 00:01:52 Source File Volume Identifier: Marvels_Daredevil_s01&_02 I 00:01:52 Source File Volume Set Identifier: 4A8D003600E676A1 I 00:01:52 Source File Application Identifier: ImgBurn v2.5.8.0 I 00:01:52 Source File Implementation Identifier: ImgBurn I 00:01:52 Source File File System(s): UDF (2.50) I 00:01:52 Destination Device: [0:0:0] TSSTcorp BDDVDW SE-506CB TS02 (H
(USB) I 00:01:52 Destination Media Type: BD-R (Disc ID: RITEK-DR3-000) I 00:01:52 Destination Media Supported Write Speeds: 2x, 4x I 00:01:52 Destination Media Sectors: 24,438,784 I 00:01:52 Write Mode: BD I 00:01:52 Write Type: DAO I 00:01:52 Write Speed: 2x I 00:01:52 Hardware Defect Management Active: No I 00:01:52 BD-R Verify Not Required: Yes I 00:01:52 Link Size: Auto I 00:01:52 Lock Volume: Yes I 00:01:53 Test Mode: No I 00:01:53 OPC: No I 00:01:53 BURN-Proof: Enabled I 00:01:53 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x) I 00:03:22 Filling Buffer... (80 MiB) I 00:03:23 Writing LeadIn... I 00:03:24 Writing Session 1 of 1... (1 Track, LBA: 0 - 15103775) I 00:03:24 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 15103775) I 00:03:24 Writing Layer 0... (LBA: 0 - 12219391) W 00:05:38 Failed to Write Sectors 643136 - 643167 - Reason: Write Error W 00:05:38 Retrying (1 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (2 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (3 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (4 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (5 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (6 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (7 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (8 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (9 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (10 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (11 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (12 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (13 of 20)... W 00:05:48 Retry Failed - Reason: Invalid Address For Write W 00:05:48 Retrying (14 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (15 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (16 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (17 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (18 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (19 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:05:49 Retrying (20 of 20)... W 00:05:49 Retry Failed - Reason: Invalid Address For Write W 00:06:15 Retrying (21)... W 00:06:15 Retry Failed - Reason: Invalid Address For Write W 00:06:16 Retrying (22)... W 00:06:16 Retry Failed - Reason: Invalid Address For Write W 00:06:17 Retrying (23)... W 00:06:17 Retry Failed - Reason: Invalid Address For Write E 00:06:23 Failed to Write Sectors 643136 - 643167 - Reason: Write Error E 00:06:23 Next Writable Address: 0 I 00:06:23 Synchronising Cache... I 00:06:35 Closing Track... I 00:06:41 Finalising Disc... E 00:07:46 Failed to Write Image! I 00:07:46 Exporting Graph Data... I 00:07:46 Graph Data File: C:\Users\BEAST\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_BDDVDW_SE-506CB_TS02_13-APRIL-2017_00-01_RITEK-DR3-000_2x.ibg I 00:07:46 Export Successfully Completed! E 00:07:46 Operation Failed! - Duration: 00:05:53 I 00:07:46 Average Write Rate: 7,185 KiB/s (1.6x) - Maximum Write Rate: 9,729 KiB/s (2.2x) I 00:08:18 Close Request Acknowledged I 00:08:18 Closing Down... I 00:08:18 Shutting down SPTI... I 00:08:18 ImgBurn closed!
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
so it may be that i am a complete idiot or this is the only way around it. just copied the same file after converting it to iso first and now it works
Having a little problem with my Blu Ray burner and AnyDVD/DVDfab
By Fantadude in forum Blu-ray RippingReplies: 9Last Post: 15th Dec 2015, 14:07 -
pioneer blu ray burner -want to make 1:1 copies of my blu ray movies
By Cool joe in forum MacReplies: 10Last Post: 10th Dec 2014, 22:31 -
LG Blu-ray Burner problem
By GeoVideo in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Apr 2014, 10:23 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 15:26 -
Problem work Subtitle in Blu-ray Player Samsung BD-C6900
By Sheva in forum Newbie / General discussionsReplies: 7Last Post: 30th Apr 2012, 11:02
