Hi all,
My head is about to explode. I've just started using the latest build of FFMPEG (with AnotherGUI frontend) and so far I thinks it's great!
What I'd like to do is convert home movie dvd rips and convert them to ProRes (for a friend who's on a mac and I am on a PC, he wants to edit the rips). I've worked out how to set resolution and aspect ratio, but the audio conversion part is cloudy. I do not have the files yet, but audio would be either ac3, wav or mp2.
So what command line options should I be looking at? There's so much stuff on Google that I am getting very confused as to what command line options I should be using.
Thanks in advance.
Best to use ProRes in a mov container with PCM (wav) audio.
-c:v prores -profile:v 0 -acodec pcm_s16le (Proxy)
-c:v prores -profile:v 1 -acodec pcm_s16le (LT)
-c:v prores -profile:v 2 -acodec pcm_s16le (422)
-c:v prores -profile:v 3 -acodec pcm_s16le (422 HQ)
https://wideopenbokeh.com/AthenasFall/?p=111 -
So by doing so will my friend have any issues with Final Cut Pro 7 or Final Cut Pro X importing the files?
Handbrake without FDK-AAC, new FFMPEG AAC encoder viable alternative?
By jaggy in forum Video ConversionReplies: 15Last Post: 27th Apr 2017, 11:31 -
Problem at efficiency of prores encoding vias ffmpeg.
By zhangjie in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2015, 04:46 -
Saving AAC audio section from mkv file in ffmpeg
By ShadowEdit in forum AudioReplies: 8Last Post: 7th Mar 2015, 16:54 -
Strange ffmpeg error when ProRes encoding
By SameSelf in forum Video ConversionReplies: 8Last Post: 25th Aug 2014, 22:34 -
FFMPEG Prores Encoder?
By Guiboche in forum Video ConversionReplies: 19Last Post: 11th May 2012, 17:40
