Hi, years ago I bought a pci card for digital and analog tv. It's called Winfast dtv2000 h, from a crappy company called Leadtek. At the time I had Win xp, and apart a couple of bugs, it worked fine.
Then I installed Win 7, the drivers didn't work, and no update was issued. I wrote the company to tell them to write the new drivers, they didn't. At a certain point I saw that Win 7 update featured a driver specifically to this card. I installed the driver from the update center, the software from the cd, but it didn't work, the software always crashed, so I dropped the thing.
Now I installed Win 10, and again the updates show there is a driver, in device manager the card is shown as working. And again the software doesn't handle it.
Is there a third party software that can read the stream from the card (and handle everything that there is to handle)?
VLC, probably, but it isn't user-friendly.
VirtualDub, amaRecTV for the analog side only. -
Run the software you have in Win 7 mode. It works for me, on win 10.
Best capture card for analog source
By Kmroc in forum Capturing and VCRReplies: 47Last Post: 8th Aug 2020, 17:30 -
Looking for a capture card that supports 960x540 qhd input
By ezcapper in forum Capturing and VCRReplies: 0Last Post: 11th Oct 2014, 11:43 -
Good Software for Capturing from Analog TV card
By vidyarathne in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2014, 12:00 -
USB 3 Analog to Digital Capture Device?
By rayjVideo in forum Capturing and VCRReplies: 3Last Post: 29th Jan 2014, 16:39 -
Hi8 analog-digital capture solution
By FGMthink2015 in forum Video ConversionReplies: 11Last Post: 9th Mar 2013, 14:54
