Hello Forum....
In not new to computers and have been taking photo's and short videos for many years. Recently however I was asked to shoot some video for a youth concert party using a hd video camera.
I now have 62 GB of 1080 mp4 footage that I need to get onto dvd for parents of the youths.
In retrospect I realise that 1080 too high a res for dvd and given that my technology is nearly antique with a very slow processor etc I need to know how to proceed. Should I convert to mpeg2 first, (Some files are 4.3 GB in size), then import to dvd flick...? If so what kind or res/bitrate should I aim for and what kind of quality should I expect?
I appreciate any help/advice from those sages who have walked these paths before me, and will totally understand if I get told to sling my hook for numerous breaches of forum rules.
Gary
Results 1 to 9 of 9
size = playtime * bitrate.
quality should I expect -
Thanks for the quick reply!
Make a test with a small clip using the bitrate you'd expect for the final dvd. Unless you have a (unusual) long playtime use the max resolution (720x480 for NTSC, 720x576 for PAL)
And my smallest clip is 900mb.
Did I say Mammoth Task? lol
And thanks for the advice.
Gary. -
Each? A total of 3 hours 20 minutes? No editing? One DVD per night? If so the final quality depends on several factors. If it's a camera mounted on a tripod in front, not moving and just capturing the action on stage, it might be doable as long as you understand it's not going to look at all like the source. A DVD is standard def where you capped in high def. If it's progressive and not interlaced, the quality will be better.
As videobruger mentioned, make a test encode using the bittrate you might use for a full encode. -
Thanks for the reply.
I will definitely make a test disc. It was tripod mounted, no movement apart from an occasional zoom (optical).
Going forward would it make sense to shoot in 720 or even 480 for DVD?
Thanks in advance
Gary. -
make a test disc
Ahhh makes good sense I have daemon tools lite for iso =)
Gary -
If you're in Scotland and (presumably) making PAL DVDs, then it's 576. But I'd still film at the highest quality possible and then downsize when encoding for DVD. And you might even wish to use the 1080 one to make a blu-ray version. Future proof it a little bit and it might not even require reencoding. But make sure to keep the 1080 version.
Thanks for replying,
I will keep the original copies of course but I think I will need better equipment before I'm ready for BR.
Dual core 4gb ram etc...
Gary.
Newbie Questions about file sizes and DVD disc sizes
By pixel_a_ted in forum Authoring (DVD)Replies: 13Last Post: 23rd Sep 2016, 10:44 -
Capture questions - Newbie
By slee02 in forum CapturingReplies: 6Last Post: 8th Oct 2015, 19:49 -
ripping dvd, newbie questions...
By VideoNoob123 in forum DVD RippingReplies: 15Last Post: 10th Nov 2014, 16:10 -
Need help authoring DVD. Seems complicated for this newbie :)
By jimbanville in forum Authoring (DVD)Replies: 7Last Post: 10th Apr 2014, 18:25
