Hey guys, I need to copy only one dvd to work on both standalone DVD players and pc's, what's the best and easiest free software I can use for this please?
Results 1 to 11 of 11
Yes, it's a wedding DVD I need to copy, Also the dvd properties on my pc shows 4.13GB and my blank Memorex DVD-R is 4.7GB so that should fit right?
Sometimes the author of wedding videos will put copy protection on the DVD. You can give it a go and see what happens. It will not hurt to try. If the DVD does have a custom copy protection applied, then DVDFab might not be able to copy it. The only way to find out is to try it.
Yes, it will fit. But Windows (?) shows GiB (though they use the symbol GB) where 1 GiB is 1024x1024x1024, or 1,073,741,824 bytes. Disc manufacturers use GB, 1000x1000x1000, or 1,000,000,000 bytes. 4.7 GB is about 4.3 GiB.
Memorex is not high quality media. Make at least three copies. Verify the discs immediately after making them, and again a few days later. Replace any that don't verify 100 percent with new copies of the original or of the remaining good discs. Then check them once a year or so, and replace any problem discs again. Use Verbatim DataLife or DataLife Plus discs for better reliability and longevity. -
Perhaps I should have been a better helper. Here is a link to the DVDFab free decrypter that should go the job without the watermark. That is assuming the version you tried did what you wanted.
http://www.dvdfab.cn/dvd-decrypter.htm
What is the best software to copy-protect dvd video files?
By tra_extra in forum Authoring (DVD)Replies: 22Last Post: 11th Sep 2015, 12:44 -
Free WinX dvd copy pro (about a day?)
By sum_guy in forum Video ConversionReplies: 2Last Post: 18th Mar 2014, 17:24 -
Odd DVD copy problem, on multiple software
By szakara in forum DVD RippingReplies: 2Last Post: 1st Mar 2013, 11:51 -
Looking for free software to convert mkv video to DVD
By jimdagys in forum Authoring (DVD)Replies: 20Last Post: 1st Nov 2012, 20:40 -
Best DVD Copy Software
By Hoogs in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2012, 10:40
