I was sent a file from a friend to see if I could get it recovered. He sent me 2 files:
Original.DAT - 600MB
Original.DMV - 129KB
Using MediaInfo on the DAT file, all I can see is that it is in QuickTime format and FileExtension_Invalid: mov qt
I've tried using VCDGear v3.55 to convert dat -> mpeg but I get this message:
I also tried using isobuster with no luck. Haven't used it before but the conversion I tried gave me a file with no data (size = 0).[ VCDGEAR PROCESSING LOG ]
## VCDGear active : 4/10/2017 @ 1:25:21 PM ##
Setting multi-file output convention to '_%02d'
Original.DAT
WARNING: Specified DAT file has an invalid XA header signature.
[Original.DAT]
Could not locate MPEG stream.
VirtualDub says Cannot Parse Original.DAT
Does anyone have other programs or ideas?
Just tried Video Repair Software by Grau GmbH with a working sample and was only able to get a video with a gray screen.
I did try uploading the video to an online converter at www.mp4repair.org and I was actually able to see some thumbnail images of the video. Great! But..... they want to charge $59 to convert the video. Not happening. It does give me some hope that somebody out there has a solution for me since an online repair tool could produce better results than I can myself in less than a minute. -
Have you tried renaming the file suffix to MPG and see whether Virtualdub or VLC can open it ?
Trying to recover a .mov file
By duket in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2015, 03:01 -
Can't recover full 4GB avi file recorded using CamStudio
By joker2013 in forum Video ConversionReplies: 4Last Post: 27th Oct 2014, 00:40 -
How to recover a delete file of Pioneer DVR-650HS
By RickS in forum Newbie / General discussionsReplies: 5Last Post: 18th Dec 2013, 01:35 -
Trying to recover a deleted file one more time.
By Shaun298 in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2013, 04:10 -
Tool to repair/recover corrupted AVC .mp4 file?
By fvisagie in forum Video ConversionReplies: 1Last Post: 15th May 2012, 07:21
