Should I resize it before mastering to DVD (say with Handbrake or MPEG Streamclip) using Toast 15 to burn the resultant file to DVD or can I just leave it as it is and let Toast just do that in the burning process? Here's the stream info:
Duration: 1:06:13
Data Size: 1200 MB
Bit Rate: 2.64 Mbps
Video Tracks:
H.264, 1280 × 720, 30 fps, 2.13 Mbps
H.264, 1280 × 720, 30 fps, 2.73 Mbps
Audio Tracks:
MPEG-4 Audio stereo, 44.1 kHz, 192 kbps
Results 1 to 11 of 11
Not DVD compliant. Generic 720p video format, burn as "data" to optical disk. Not universally playable.
30fps is not PAL.
PAL/NTSC DVD specs: https://www.videohelp.com/dvd#tech- My sister Ann's brother -
Assuming you are burning this for set top players. Use a good authoring software like AVStoDVD. Even the defaults will give you excellent results. PAL players will generally play NTSC, so you only need to make one version.
edit: Oops you said Toast. You're on a mac. Nevermind. -
I don't think you understand the DVD format, or else what you're trying to get isn't "DVD". Are you trying to make this video an authored DVD disc? If so, you can't use 1280x720 for DVD.
If you want an AVCHD video authored and/or burned to DVD disc, 30fps isn't valid for the AVCHD 720p spec. An AVCHD or BluRay 720p video must be either double frame rate (60 or 50 fps) or film speed (23.976 or 24 fps). 30 fps is not valid for those formats if you want playable AVCHD or BluRay.
An audio rate of 44.1 KHz isn't valid for either DVD or AVCHD.
Resizing for "DVD" means re-encoding, and both processes will be a quality hit. How little or how much depends on how it's done.
What you have can be burned as "data" to a DVD optical disc and played as-is. But some playback devices may refuse to play that format from optical disc. Some devices, but not all, can play it if copied directly as-is to USB stick or external hard drive.- My sister Ann's brother -
I think that thus far I've expressed myself poorly here. So I'll try to eliminate any ambiguity.
So my footage, which I wish to transfer to DVD using Toast 15 with as little loss as possible, is currently 1280 x 720 and 30fps. Simply pasting this footage into Toast 15 means that the DVD burning software converts it to the required DVD standard, be it PAL or NTSC. What though I'm trying to ascertain is whether it would be better for me, quality-wise, to resize the footage prior to burning to Toast (and if so, to what specs?) Or is the aforementioned method the best all things considered? -
Resizing progressive footage is in general not a problem. Note you keep a little bit of more detail in PAL version (720x576) as oppose to NTSC (720x480), but frame rate is changed on the other hand.
What is your video frame rate exactly? 29.97p or 30p? DVD specs are 29.97 fps interlaced 720x480 for NTSC and 25.000fps interlaced 720x576 for PAL.
So I'd be concerned for frame rate conversion rather than downscale, what Toast would do with that original 30p. Re-samples to 29.97i , every frame? That'd be kind of not necessary. Then I'd rather used assumefps("ntsc_video") in avisynth and encoded separately (heck even encoded to 29.97p with HcEncoder), and adjusted audio as well, because audio would shift out of sync in time, but that I'd do on Windows, just an opinion, you stress your concern about quality and I have no idea how to do it on Mac. Also assuming Toast would just create fields, top and bottom from one progressive frame. Same concerns for resample to 25 fps, but in that case you must resample (not really, as smrpix says, DVD PAL players in Europe can play NTSC DVD's not sure what you are planning to do with it).
You can easily do a test, make a DVD , a VIDEO_TS with Toast, one time NTSC, one time PAL, from one video clip, where is something moving, horizontally, look at it. -
Thanks. I use a Mac by the way. The mp4s in question were shot at an event using a digital camera. I think the specs are given in my earlier posting but how do I ascertain whether it's interlaced or progressive? I am happy to make an NTSC format DVD even tho I'm in the UK, our players, as you say, handle those fine but so far the jerkiness has spoilt my efforts!
Toast will probably discard one frame out of every 1001 frames to convert 30 fps to 29.97 fps, about 1 frame every 30 seconds. Probably not worth worrying about, even if it doesn't do it in a smart way (eg, taking the frame out of a still shot instead of in the middle of a panning shot).
Although it's not foolproof, you can use MediaInfo to determine if your video is interlaced or progressive.
Reducing ghosting on 25FPS and 30FPS mixed footage in Vegas Pro 12
By guitarman320 in forum Video ConversionReplies: 6Last Post: 4th Jan 2017, 19:39 -
Need to convert 60fps footage to 30fps fully-preserved for YouTube
By Hero of Legend in forum Video ConversionReplies: 65Last Post: 12th Feb 2015, 08:02 -
How do I convert HD NTSC footage into HD PAL - what frame rate is best ?
By Bansaw in forum EditingReplies: 18Last Post: 21st Nov 2014, 17:27 -
Will a PAL AV Receiver handle NTSC (30fps) HDMI passthrough?
By Babe RuthLess in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2014, 11:20 -
1080p 30fps to 720x576i 25fps Pal Help please
By Prototype_uk in forum Video ConversionReplies: 8Last Post: 27th Nov 2012, 18:03
