I have an mkv file with multiple audio sources and took it apart to remove all but the english one
This is an AC3 file which i'm trying to merge using MKVToolnix. The problem is that this AC3 track shows 2 times in Media Player Classic
So far i tried all options in MKV Toolnix for 'Default track' 'Froced track' and AC3 shows up even if i use a different DTS audio file. Why?
	Why not use MKVToolnix to strip out the unwanted tracks without taking it apart?
	Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
	YES. I moved the audio files to another directory and it worked. LOL why does media player classic load audio files from a directory ? Thanks Last edited by Kand; 9th Apr 2017 at 08:30.
  Used mkvtoolnix and need help making audio from mka to ac3 Major help pleasBy csta in forum AudioReplies: 10Last Post: 2nd Aug 2017, 11:03
  Need Help! LPCM, TrueHD & 7.1ch to AC3!!By botdvd in forum Video ConversionReplies: 4Last Post: 28th May 2016, 22:21
  TsMuxer - AC3 & fpsBy leetxjd in forum Authoring (Blu-ray)Replies: 3Last Post: 23rd Nov 2014, 22:36
  Audio does not play on PS3 - Xvid 64 & AC3By brokenxx in forum AudioReplies: 6Last Post: 22nd Aug 2013, 00:35
  MKVToolnix - cropping or changing display & width heightBy wacus in forum Newbie / General discussionsReplies: 9Last Post: 6th Jul 2013, 14:30
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
