    Sep 2014
    Rome
    Hi
    i 'm mosly a premire cc sub user ,but often i have to use vegas ,in my case vegas 13
    on my video ,i have added 3 video FX color correction, gaussian blur and level and i have added several keyframes
    can i edit these keyframe in the timeline ?
    i have selected the envelope edit tool and i have tried to right click on the video track insert envelope
    but i can't edit my effects ,i have no color corretion or gaussian blur in the list
    can i do it with vegas?
    under premiere cc in the timeline i drag an effect like blur and right click and i have the envelope
    thanks
    sorry for my poor english
  2. Being also mostly familiar with Premiere, I was curious about this also. It turns out, you can animate the effect with keyframes, much like in Premiere.
    Sep 2014
    Rome
    hi
    thanks for the answer
    but in premiere you can work on the envelope with the pentool in the timeline , you can add keyframe directly in the timeline and control every effects
    it's enough add an effect to a clip on the timeline ,right click on fx (on the clip) and you can select an envelope
    i would like to know if can do the same with sony vegas 13
    thanks
  4. you can animate clip, right clicking it, video event fx or clicking that green effect icon on the event (clip) in timeline, click that animate button if you cannot see keyframes
    you can animate a video track alone, selecting that effect icon on the left at the beginning of each track
    you can apply effects to the whole timeline using Video bus track (file/show video bus track) using the same icon on the left on that Video bus track, you apply things to the whole timeline, all tracks (sequence in premiere terms)
    right click keyframes, you have some curves there but not graphical tuning up creating curves
    envelopes are used for speed (green), motion blur (purple), composite level (dark blue), fade (red), volume and pan by sound (dark blue and brown) , right click created points and you can select different curving, also right click transition/fade type and you get curves for transitions, that feature alone is really handy
    clip are called events in vegas
    Sep 2014
    Rome
    hi
    thanks a lot
    so i can't have envolope for gaussian blur on the event(clip) ,can it?
    i have read all thanks a lot!!!
  6. no envelope, you can create keyframes and you have couple of choices there, how it curves going thru that particular keyframe, nothing visual i'm afraid or regulating that curve like in after effects or Premiere
    maybe there are some plugins to get those curves, there is tons of stuff for Vegas
  7. Originally Posted by rama View Post
    Not the way you want it to work... The curves can be accessed on the video track fx box , not on the timeline itself.
    If you need to access it on the timeline as an envelope, a workaround is 2 layers, one with the gaussian blur (on top), one without . Insert track composite level video envelope on the top layer and add control points (shift click). But if you have multiple effects, more complex project with layers it's probably not a suitable workaround
    Sep 2014
    Rome
    hi
    thanks for the tips
    they have not added feature like this in vegas 14 (the new version)?
