Hi ,
I have lots of video clips and I find I often want to edit them down... just save the best bits .....
Im wondering is there a simple video editor that would let me cut out the junk and just save the best ?
Ive got V Dub and that does do that .. but you have to start converting your vid to mpeg 1 before it will work in there
Im thinking of some software that will take most vid formats.... mpeg 4 etc and do the job
thanks for any advice
Results 1 to 11 of 11
You could try Virtualdub FilterMod (see the Virtualdub page here at VH and scroll down to "Alternative to Virtualdub") it's a fork/continuation of Vdub that is still being worked on. What types of file are you working with?
Ive got a mixture of file types, prob most are mp4 ... last time I used v dub Im sure I had
to convert every file to mpeg 1 before it worked in there,,,, maybe things have moved on ?
I was wondering could the you tube video editor do the job ? or maybe some other online video editor ? -
Just had a go with the You Tube editor..... seems quite good, managed to delete selected bits of a video ,
you can use it to join videos together.... put audio tracks on,,, get transitions etc -
As I said, you might want to try "Virtualdub FilterMod" as it's a continuation of Vdub that accepts many more video types now than the original Vdub, and is still being worked on.
Thanks for the link.... looks worthwhile getting hold of it ...
the U Tube free online editing feature looks good too..... though when they say they are processing your video...
thats a code word for censoring your video !
Just hit on ............. I Spring ..... its a video capture software.... or should that be screen capture ?
anyway it lets you record any action thats happening on your screen.... maybe a movie... maybe U Tube ... and the end
result is good..... even better than the Icecream vid capture
Ive got a ton of old videos that Im going thru... getting the best bits onto dvd s and getting those onto the comp
Im using mainly....Kompact dvd .... and Data Cell dv d
Just put about 24 vid clips onto a dvd and find that the dvd recorder wont finalize the disc....
looks like a faulty disc
this is happening too often lately .... should I be using better quality dvd discs ? any advice ? -
I don't know why everyone thinks that computer software should be free. Yes there is some good free software, but when it comes to editing video, the commercial software is more fully featured. For $50, which is not much money, you could get Pinnacle Studio (or whatever it is now called) or Vegas Movie Studio. I recommend these because they give you so many more options and are so much easier to use than VirtualDub (which I use every day, but not for full-blown editing). If you have a lot of tapes, you'll end up with a better result, and you'll get to the finish line so much quicker, that the $50 will mean nothing.
Careful.
DaVinci Resolve isn't really free. There are a bunch of hidden costs (maybe not in outright dollars, but definitely in hair lost). First, BMD only supports Win10 (sorry XP/7/8 fanbois). Second, it doesn't support some key codecs (q.v. DV-AVI, M2TS). Third, if it doesn't outright crash your system, it will run agonizingly slow, making editing virtually impossible (q.v. h.264 support). Fourth, well, I could go on, but why? Don't be fooled by the $0 price tag. I much rather spend $50 versus enduring the pain involved learning DR and all its gotchas if all I wanted to do was edit my video. However, DR is a fantastic grading program.
As for Lightworks, that is a painful NLE to use without a control surface/keyboard (which I think only work with the pro version).
Full disclosure: I say this as a Premiere Pro user (although I suspect the legions of Vegas Pro users would say the same), not someone who struggles with an Avisynth/vdub workflow (which are useful for dealing with legacy NTSC footage, otherwise sorely out of date with modern workflows/cameras, imho).
Editing Drive Trip Videos
By CTPete in forum EditingReplies: 2Last Post: 26th Oct 2016, 03:39 -
Editing old videos?
By lostsoul65 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2015, 12:41 -
Need help in editing two videos of different length
By Freelife2345 in forum EditingReplies: 22Last Post: 5th Mar 2015, 19:29 -
Alright I need help editing videos
By trailshredder in forum EditingReplies: 6Last Post: 5th Mar 2015, 10:24 -
Program for editing videos with encrypted segments from videos from satelit
By calriks in forum EditingReplies: 1Last Post: 3rd Jul 2014, 21:33
