Results 1 to 14 of 14
  1. script
    Mpeg2Source("I:\VIDEO_TS.d2v", CPU2="ooooxx")
    return
    \ fa.Trim(0, 16785)
    \ + fb.Trim(16786, 16817)
    \ + fa.Trim(16818, 17384)
    \ + fb.Trim(17385, 17469)
    \ + fa.Trim(17470, 17563)
    \ + fb.Trim(17564, 17596)
    \ + fa.Trim(17597, 18849)
    \ + fb.Trim(18850, 18964)
    \ + fa.Trim(18965, 19189)
    \ + fb.Trim(19190, 19288)
    \ + fa.Trim(19289, 21519)
    \ + fb.Trim(21520, 21606)
    \ + fa.Trim(21607, 22061)
    \ + fb.Trim(22062, 22195)
    \ + fa.Trim(22196, 27773)
    \ + fb.Trim(27774, 27797)
    \ + fa.Trim(27798, 29724)
    \ + fb.Trim(29725, 29733)
    \ + fa.Trim(29734, 30767)
    \ + fb.Trim(30768, 30931)
    \ + fa.Trim(30932, 32137)
    \ + fb.Trim(32138, 32378)
    \ + fa.Trim(32378, 32875)
    \ + fb.Trim(32876, 33032)
    \ + fa.Trim(33033, 33930)
    \ + fb.Trim(33931, 33979)
    \ + fa.Trim(33980, 37811)
    function fa(clip C)
    C
    TFM()
    TDecimate(Mode=1)
    ColorMatrix(mode="rec.601->rec.709")
    ColorYUV(cont_y=5, cont_u=-40, cont_v=8, gamma_y=-15)
    Crop(4,0,-0,-0)
    McTemporalDenoise(settings="Low")
    nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720)
    Sharpen(0.7)
    McTemporalDenoise(settings="Medium")
    Hysteria(strength=3.6, maxchg=26,lowthresh=12)
    Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3)
    Blur(0.8)
    return Last
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    TDecimate(Mode=1)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
  2. Did you really mean to call MCTD twice in fa()? You may be running out of memory.
  3. Originally Posted by jagabo View Post
    yes
    if i reduce the number of trims it works
    how can i make it work ?
  4. Using a random DVD MPEG2 video your script crashed on my computer too. But not after modifying it to use ReplaceFramesSimple():
    Mpeg2Source(I:\VIDEO_TS.d2v", CPU2="ooooxx")
    va = fa()
    vb = fb()
    ReplaceFramesSimple(va, vb, mappings="
    [16786 16817][17385 17469][17564 17596][18850 18964][19190 19288]
    [21520 21606][22062 22195][27774 27797][29725 29733][30768 30931]
    [32138 32378][32876 33032][33931 33979][33980 37811]")
    Trim(0,37811) # in case va is longer than 37812 frames.
    return(last)
    function fa(clip C)
    C
    TFM()
    TDecimate(Mode=1)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    TDecimate(Mode=1)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
  5. Originally Posted by jagabo View Post
    va = fa()
    vb = fb()
    return(last)
    function fa(clip C)
    C
    TFM()
    TDecimate(Mode=1)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    TDecimate(Mode=1)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
    it works ! thanks
    what does it do differently ?
    my script basically tell use A or B in the different trimmed sections
    your replaces or something ?
  6. I think AviSynth creates a new video stream with each of your calls to fa() and fb(), 27 different streams, each calling memory intensive filters like MCTD and QTGMC. I'm my version fa() and fb() are called only once, so only two streams are created. If you modified your code to do something like:
    va = fa()
    vb = fb()
    return(va.Trim(0, 16785)
    \ + vb.Trim(16786, 16817)
    \ + va.Trim(16818, 17384)...
    It probably would have worked.
    I think VirtualDub creates a new video stream with each of your calls to fa() and fb(), 27 different streams, each calling memory intensive filters like MCTD and QTGMC. I'm my version fa() and fb() are called only once, so only two streams are created. If you modified your code to do something like:
    va = fa()
    vb = fb()
    does your code does what my script intended? the parts with fa the default is applied to them and to fb the QTGMC...
    it doesnt replace ALL of the trimmed sections with "fb" (QTGMC one) right?
    Edit:nvm
  8. Why don't you just check it and find out?
  9. I had some time so I double checked my script in post 5. The last segment in ReplaceFramesSimple, [33980 37811], should be removed. The script in post 7 is obviously just a fragment -- you should be able to figure out the rest.
    yes i figured it out myself and that you only used the "fb" frames
    i already finished encoding
    crap i forgot 2 sections that also has bad interlacing and need a fix.
    [28819 28879][26199 26421]
    the video is already encoded ...
    what is the fastest way to fix this sections?
  12. Originally Posted by zanzar View Post
    The best and easiest way is to add those two sections to the script and encode the whole video again.
  13. Originally Posted by jagabo View Post
    what would be the downside by using something like this ?
    LWLibavVideoSource("I:1.mkv") # "1" is the encoded video with the missing parts
    vb = fb()
    ReplaceFramesSimple(vb, mappings="[28819 28879][26199 26421]")
    return(last)
    function fb(clip C)
    C
    QTGMC(FPSDivisor=2)
    TDecimate(Mode=1)
    ColorYUV(cont_y=5, cont_u=-10, cont_v=8, gamma_y=-15)
    Crop(4,0,-0,-0)
    Sharpen(0.7)
    Blur(0.8)
    return Last
  14. Re-compressing the video will cause a loss of quality.
