Results 1 to 18 of 18
    Jun 2005
    Vermont
    Does anyone know of a free audio converter that will convert a Real Player ram file to mp3?
  2. Member bat999's Avatar
    Feb 2008
    Originally Posted by dfisher052 View Post
    ... a Real Player ram file...
    Hi
    Are you sure that the "ram" file is an audio file?
    Usually Real Player audio files end in .ra or .rm.
    Often the "ram" files only contain information pointing to an audio stream on a website.
    Jun 2005
    Vermont
    It plays in VLC as an audio. If I change it to ra it still plays as an audio. I want to change it to mp3 so I can play it in my mp3 player. I have a couple of audio converters, but they do not accept ram, ra or rm.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    There are many audio conversion programs that will do this - just Google and you will find them, as a starter check this out Pazera Free Audio Extractor is will convert .RA files to AC3 or MP3 etc...
  5. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    Westernmost point of Europe
    If VLC plays it, VLC will probably be able to convert it too.
    "The greatest trick the Devil ever pulled was convincing the world he didn't exist."
    Jun 2005
    Vermont
    Tried both Pazera and VLC. Neither one worked.
  7. If VLC can play it it should also be able to convert it. You must be doing it wrong. Since VLC is based on ffmpeg there should be thousands of other ffmpeg based softwares who can do it as well. You could of course try ffmpeg itself:
    ffmpeg -i "input.ram" "output.mp3"
    Or a GUI like TEncoder. And don't say "didn't work", post what exactly you are trying and what error messages, if any, there are. If you believe it's not your fault upload a sample file here so we can check.
  8. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Pazera works for me - upload a sample file
    Jun 2005
    Vermont
    Never having done this before I do NOT know how to get the ra file into this post. Any help?
  10. Click on the "Upload files/Manage attachments" button below the edit box.
    [Attachment 41171 - Click to enlarge]
    Then select the file, upload it, wait for it to finish, and close the popup. Only certain types of files are allowed. I don't know if .RAM is one of them. You may have to archive the file and upload it as .ZIP.
    Jun 2005
    Vermont
    I think this worked.
  12. A Member since June, 2004 Keyser's Avatar
    Feb 2013
    As suspected, your .ra file contains just a link to the actual media. Open the .ra file in a text editor (like notepad) and paste the link to the VLC converter. I tested it. It works!
    Alternatively, you can paste the link to your browser and download the .rm file.
  13. Converting the downloaded .rm file to mp3 also works in Pazera, Audacity or with NCH Switch converter (free version)..
  14. Originally Posted by dfisher052 View Post
    I think this worked. (ZIP file)
    You really thought they were able to encode two hours of audio in a 64 byte file? The others are right. The file isn't an audio file, it's a only a link to:
    http://vintageradioclassics.com/realaudio/radioclassics170101.rm
  15. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    This is the Mediainfo report on the file I converted using Pazera.
    General
    Complete name : C:\Users\Netmask\Downloads\sample.ra
    Format : RealMedia
    File size : 27.8 KiB
    Duration : 3 s 482 ms
    Overall bit rate : 64.0 kb/s
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : dnet
    Codec ID/Info : Real Player 3
    Bit rate : 64.0 kb/s
    Channel(s) : 1 channel
    Sampling rate : 11.025 kHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 27.2 KiB (98%)
    Jun 2005
    Vermont
    According to VLC codec Information, this file is: MPEG AAC Audio (raac).
    When I changed ra to mpeg it still played in VLC but would still not convert in ANY of the converters I tried, including all mentioned here. I think I've given up on this one. Thanks all for your input.
  17. VLC had no problem converting the rm file to mp3. Either by first downloading the RM file and converting it, or by converting directly via the URL.
  18. Member
    Jun 2005
    Vermont
    Thanks jagabo for url suggestion...that worked.
