I have several videos in 10 bit, but how can I be sure to watch the files in true 10 bit on my screen? Are there any test files or anything else I can do to test it?
Thank you, sneaker, I saw you already in many other places
Does HDMI 2.0 allow 3840x2160 with 60 Hz in 4:4:4 with 10 bit color depth? Cannot find a real answer...
... reading the doom9 thread ... -
Ok, I see. What is the maximum to get out of HDMI 2.0?
3840x2160 / 60Hz / 10 bit color depth
-> Which pixel format?
What is the difference of the supported pixel formates:
YCbCr 4:2:0
YCbCr 4:2:2
YCbCr 4:4:4
RGB 4:4:4 (Full RGB)
RGB 4:4:4 (Studio RGB) -
You need a monitor capable of outputting a 30bit signal (10bits per color channel), note NOT 24bit or 32bit which is actually referring to 3 8bit channels and Alpha, and you need a graphics card that is capable of outputting same, via DX Geforce cards have been able to do it since the GTX285 days but if you're using OpenGL you will need a Quadro.
Same holds true for AMD cards, you will need a FirePro if you want to output a 10bit signal via OpenGL.
Which device can capture component video in 10bit 4:2:2 color?
By digicube in forum Capturing and VCRReplies: 11Last Post: 30th Oct 2016, 14:08 -
FFMPEG x265 10bit and virtualdub x265 10bit settings
By lilycarolyn in forum Video ConversionReplies: 11Last Post: 6th Jun 2016, 14:44 -
How do I convert 1080p 10bit mkv's to 720p 10bit?
By fighuass in forum Video ConversionReplies: 6Last Post: 19th Nov 2015, 02:34 -
Vidcoder on 10bit to 8bit anime videos
By blinkmadden in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2013, 09:18 -
How to removed parts from 10bit mkv videos?
By Choey in forum EditingReplies: 5Last Post: 28th Jul 2013, 01:14
