So I've got a UHD Blu Ray copy of Angry Birds and I'm having massive issues using handbrake to compress it. I like to passthru the audio with all my files while compressing it to x265 with a constant RF quality of 24. I've been doing this for years now with all my movies and TV shows and never had an issue except only with this file. The problem is handbrake is only exporting the x265 stream and not the DTS-HD audio track along with it. I tried converting it to AC3, and AAC and the sound stops playing after about 10 seconds. I also tried demuxing the mkv and adding the audio track to my compressed video track and they are massively out of sync. This is all really weird because I tried playing the MKV and it works perfectly in sync throughout the whole film. Someone please help!
Try ffmpeg:
ffmpeg -i "input.mkv" -af aresample=async=1 "output.flac"
The file is probably broken somehow. If it's just the first 10 seconds: do you need them? Often just logos/trailers. Could cut them away using mkvmerge or HandBrake itself. It has an option to select only specific part of the source. So start at e.g. 20 seconds and see if that works. -
I downloaded it and it isn't opening for me. I also noticed from the SS its a command prompt tool which I have no idea how to use. Lastly are you saying to use this on the desync'd file?
Copy ffmpeg.exe to the folder of the input file(*). Hold shift and right-click on an empty space in the Windows explorer and click "Open command window here". Then enter the command I posted in the other post and hit enter.
On the original file.
(*) More elegant is to put ffmpeg into its own folder and add that to %PATH%. Then you can use it from any folder. -
Same post as here - https://forum.videohelp.com/threads/383128-Need-Help-with-Pesky-Audio-Track
DVDFab Announces no AACS 2.0 decryption to crack the next-gen 4K UHD Blu-ra
By DVDFab Staff in forum Newbie / General discussionsReplies: 27Last Post: 18th Apr 2016, 11:17 -
Blu-ray UHD Spec Released
By SameSelf in forum Latest Video NewsReplies: 89Last Post: 11th Apr 2016, 13:38 -
Help Compressing MP4 for Blu Ray Burning
By Batmaniac in forum Newbie / General discussionsReplies: 9Last Post: 19th Apr 2013, 15:19 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 15:26 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15
