lets say i have a 30min video and i want to use "QTGMC(FPSDivisor=2)" on a few frames to fix interlacing problem
script :
Mpeg2Source("i:\VIDEO_TS.d2v", CPU2="ooooxx")
TFM().TDecimate(Mode=1)
ColorMatrix(mode="rec.601->rec.709")
ColorYUV(cont_y=10, cont_u=0, cont_v=20,gamma_y=-10)
McTemporalDenoise(settings="Low")
nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720)
Sharpen(0.7)
McTemporalDenoise(settings="Medium")
Hysteria(strength=3.0, maxchg=24,lowthresh=12)
Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3)
Blur(0.6)
Results 1 to 10 of 10
Create two videos, one with QTGMC() one without, then use Trim() or ReplaceFramesSimple().
the thing is , they are in different parts in the video and for all the other "normal parts" i am using the original script
is there a way to set a group like
a= from frame 10000 to 11000 use QTGMC()+ the original script
b= from frame 15000 to 16000 use QTGMC()+ the original script
c= from frame 20000 to 21000 use QTGMC()+ the original script
and for all the other just use the original one -
ReplaceFramesSimple() is made just for that type of replacement.
Code:ReplaceFramesSimple(VidWithoutQTGMC, VidWithQTGMC, mappings="[10000 11000] [15000 16000] [20000 21000]")
You don't have to encode the whole video twice. Just create the QTGMC processed video to your current script.
Code:VidWithoutQTGMC = src.Whatever() VidWithQTGMC = src.WhateverIncludingQTGMC() ReplaceFramesSimple(VidWithoutQTGMC, VidWithQTGMC, mappings="[10000 11000] [15000 16000] [20000 21000]")
Maybe he means filtering is so slow he doesn't want to do it twice with 2-pass encoding?
You can encode to a lossless (e.g. x264 --qp 0) or near-lossless intermediate file first and then do the actual encoding passes from that one later. (I'm wondering if doing the first pass on the not deinterlaced source would be good enough. Or just a very fast deinterlacer on the first pass. That might also be a viable option.) -
The OP hasn't stated how he wants to use QTGMC in that script. It could be used instead of TFM(), for example:
or after TFM().TDecimate():Code:Mpeg2Source("i:\VIDEO_TS.d2v", CPU2="ooooxx") v1 = TFM() v2 = QTGMC(FPSDivisor=2) ReplaceFramesSimple(v1, v2, mappings="[10000 11000] [15000 16000] [20000 21000]") TDecimate(Mode=1) ColorMatrix(mode="rec.601->rec.709") ColorYUV(cont_y=10, cont_u=0, cont_v=20,gamma_y=-10) McTemporalDenoise(settings="Low") nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720) Sharpen(0.7) McTemporalDenoise(settings="Medium") Hysteria(strength=3.0, maxchg=24,lowthresh=12) Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3) Blur(0.6)
Note that the frame numbers will be different than in the first case because the video has already been decimatedCode:Mpeg2Source("i:\VIDEO_TS.d2v", CPU2="ooooxx") TFM().TDecimate(Mode=1) v2 = QTGMC(FPSDivisor=2) ReplaceFramesSimple(last, v2, mappings="[10000 11000] [15000 16000] [20000 21000]") ColorMatrix(mode="rec.601->rec.709") ColorYUV(cont_y=10, cont_u=0, cont_v=20,gamma_y=-10) McTemporalDenoise(settings="Low") nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720) Sharpen(0.7) McTemporalDenoise(settings="Medium") Hysteria(strength=3.0, maxchg=24,lowthresh=12) Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3) Blur(0.6)
In both cases QTGMC() will not slow down the processing of frames 0-9999, 11001-14999, 16001-19999, and 21001 to the end. -
I may not be understanding either. But, it might be slow to open because it'll behave as if opening a script using QTGMC over the entire script. However, during the actual encoding, only the QTGMC parts will encode more slowly than the rest of the script. If QTGMC isn't used much in the RemapFramesSimple portion of the script, then the entire encode won't take much longer than if QTGMC hadn't been used at all. You mentioned there were only a few frames needing it.
In addition, as you know, there are various settings for QTGMC that speed it up. In addition, you might be able to tighten up the CThresh setting in TFM to pick up the interlaced frames to begin with.
Apply filter settings to all files in XviD4PSP 7
By eday_2010 in forum Video ConversionReplies: 1Last Post: 19th Dec 2016, 22:09 -
Apply Yadif using complex filter in FFmpeg
By panzerIV in forum EditingReplies: 4Last Post: 5th Jul 2016, 05:14 -
How to apply time stretch filter to avi file in VirtualDub
By ezcapper in forum Video ConversionReplies: 0Last Post: 29th Jun 2015, 23:43 -
App or plugin/filter to interpolate fields/frames to turn 29.97 into 59.94?
By brassplyer in forum RestorationReplies: 3Last Post: 31st Jan 2014, 10:55 -
Audio Track on x264.. how i can apply -xdb filter whitout loss quality ??
By DjDiabolik in forum Video ConversionReplies: 0Last Post: 17th Jun 2013, 14:58
