hi guys
ok bought a dvd writer
toshiba cdrw dvd rom sd r1002
came with nereo 5.5
just wonder how to burn original dvdz
can i burn disc to disc or have to do something else
or does anybody no of a good turtorial site thats easy to follow
also can i use easy cd creator 5 plat and not nero 5.5 or clone
help would be greatful
Copyman, re-read your post I think you made a mistake you said you bought a dvd burner on the first line but the second line says dvd rom. If you are looking to make vcd's with you cdr burner then your in the right place. however if you your looking to make dvd's then check out www.doom9.com or look at the links page to your left
Copyman-
I don't mean to burst your bubble, but if you bought a:
like you said you did, then you didn't get a DVD writer...this drive will read CDs and DVDs and it will ONLY write CDs...so you can use this drive to burn VCDs, but there is NO WAY that you can burn DVDs of any type with this drive...if you made a typing error in your question, then thats one thing, but if you thought you bought a drive that can burn DVDs, then do some more research next time before you make a purchase... -
If you didnt spend like 400-700 dollars for the drive, its a CDrw. Not DVD-RW. These are hybrid drives that read/write cds. But only READ DVD discs. Sorry.
Hello....I need some help coping some of my avi files and jpg files to a vcd that I can play on my dvd... I've only had minimal success with avi files and don't have a clue how to do the jpg...Thanks for any help...Cuda
Beracuda, you accidentally asked a question under somebody else's question, so I doubt you will find this again.
beracuda, try the guides under HOW TO on the left side of your screen.
Read about what exactly VCDs are in the WHAT IS.
The guides and how-to's are excellent, and some may even cover your specific hardware.
You will probably be using this one, so here is a link:
http://www.vcdhelp.com/tmpgenc.htm
It takes time to learn it all, I like to print things out and read them when I have a minute.
good luck.
k
newbie questions about ffmpegx
By Anoni in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 10:11 -
Newbie Software Questions
By AAOBill in forum Newbie / General discussionsReplies: 1Last Post: 12th Mar 2010, 23:42 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 14:16 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 09:19 -
Newbie Mplayer questions
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 21st Dec 2007, 13:51
