    Apr 2017
    So i have a ZEEVEE ZvPro820 that has the ability to play a video loop from an internal SD card and inject it into a CATV channel. Problem is, the software that converts video files to it's ZVC format is Windows based (we use linux), it is incredibly slow (doesnt multithread), and the converter has a poor encoding algorithm (video looks choppy compared to my own attempt to replicate). So here is what i know:
    ZVC file is basically an mpg file using MPEG-1/2 (mpgv) the problem is the audio is encoded in an unfamiliar way. The ZvPro unit reports that the audio stream is invalid when i encode an mpg file with AAC, AC2, mpga, mp2, etc...
    Here is the console data for the regular mpg file that i created on my own:
    mediainfo --fullscan sample.mpeg1-2.mpgv.mpg
    General
    Count : 308
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Count of video streams : 1
    Count of audio streams : 1
    Video_Format_List : MPEG Video
    Video_Format_WithHint_List : MPEG Video
    Codecs Video : MPEG-2 Video
    Audio_Format_List : MPEG Audio
    Audio_Format_WithHint_List : MPEG Audio
    Audio codecs : MPEG-1 Audio layer 2
    Complete name : sample.mpeg1-2.mpgv.mpg
    File name : sample.mpeg1-2.mpgv
    File extension : mpg
    Format : MPEG-PS
    Format : MPEG-PS
    Format/Extensions usually used : mpeg mpg m2p vob pss
    Commercial name : MPEG-PS
    Internet media type : video/MP2P
    Codec : MPEG-PS
    Codec : MPEG-PS
    Codec/Extensions usually used : mpeg mpg m2p vob pss
    File size : 1923072
    File size : 1.83 MiB
    File size : 2 MiB
    File size : 1.8 MiB
    File size : 1.834 MiB
    Duration : 3240
    Duration : 3s 240ms
    Duration : 3s 240ms
    Duration : 3s 240ms
    Duration : 00:00:03.240
    Duration : 00:00:03;07
    Duration : 00:00:03.240 (00:00:03;07)
    Overall bit rate mode : VBR
    Overall bit rate : 4748326
    Overall bit rate : 4 748 Kbps
    Frame rate : 29.970
    Frame rate : 29.970 fps
    Frame count : 97
    Stream size : 40155
    Stream size : 39.2 KiB (2%)
    Stream size : 39 KiB
    Stream size : 39.21 KiB
    Proportion of this stream : 0.02088
    File last modification date : UTC 2017-04-05 13:32:53
    File last modification date (local) : 2017-04-05 09:32:53
    Video
    Count : 312
    Kind of stream : Video
    StreamOrder : 0
    FirstPacketOrder : 0
    Format : MPEG Video
    Commercial name : HDV 720p
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings : BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Internet media type : video/MPV
    Codec : MPEG-2V
    Codec : MPEG-2 Video
    Codec/Family : MPEG-V
    Codec profile : Main@High 1440
    Codec settings, Matrix : Default
    Duration : 3237
    Duration : 3s 237ms
    Duration : 3s 237ms
    Duration : 3s 237ms
    Duration : 00:00:03.237
    Duration : 00:00:03:07
    Duration : 00:00:03.237 (00:00:03:07)
    Bit rate mode : VBR
    Bit rate mode : Variable
    Bit rate : 4397834
    Bit rate : 4 398 Kbps
    Width : 1280
    Width : 1 280 pixels
    Height : 720
    Height : 720 pixels
    Pixel aspect ratio : 1.000
    Display aspect ratio : 1.778
    Display aspect ratio : 16:9
    Frame rate : 29.970
    Frame count : 97
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.159
    Delay : 0.000
    Delay : 00:00:00.000
    Delay_DropFrame : No
    Delay, origin : Container
    Delay_Original : 0
    Delay_Original : 00:00:00.000
    Delay_Original_Settings : drop_frame_flag=0 / closed_gop=0 / broken_link=0
    Delay_Original_DropFrame : No
    Delay_Original_Source : Stream
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    GOP, Open/Closed : Open
    Stream size : 1779237
    Stream size : 1.70 MiB (93%)
    Stream size : 2 MiB
    Stream size : 1.7 MiB
    Stream size : 1.697 MiB
    Proportion of this stream : 0.92521
    Buffer size : 141312
    intra_dc_precision : 8
    Audio
    Count : 254
    Kind of stream : Audio
    StreamOrder : 1
    FirstPacketOrder : 1
    Format : MPEG Audio
    Commercial name : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Internet media type : audio/mpeg
    Codec : MPA1L2
    Codec : MPEG-1 Audio layer 2
    Duration : 3240
    Duration : 3s 240ms
    Duration : 3s 240ms
    Duration : 3s 240ms
    Bit rate mode : CBR
    Bit rate mode : Constant
    Bit rate : 256000
    Bit rate : 256 Kbps
    Channel(s) : 2
    Channel(s) : 2 channels
    Sampling rate : 48000
    Sampling rate : 48.0 KHz
    Samples count : 155520
    Frame count : 135
    Delay : 0.000
    Delay relative to video : 0
    Delay relative to video : 00:00:00.000
    Video0 delay : 0
    Video0 delay : 00:00:00.000
    Stream size : 103680
    Stream size : 101 KiB (5%)
    Stream size : 101.2 KiB
    Proportion of this stream : 0.05391
    Below is the console data on the converted file (above), after it has been converted to a zvc file using the ZeeVee converter application.
    mediainfo --fullscan sample.mpeg1-2.mpgv.zvc
    General
    Count : 308
    Complete name : sample.mpeg1-2.mpgv.zvc
    File extension : zvc
    Format : MPEG Video
    Format : MPEG Video
    Format/Extensions usually used : mpgv mpv mp1v m1v mp2v m2v
    Commercial name : MPEG Video
    Codec : MPEG Video
    Codec : MPEG Video
    Codec/Extensions usually used : mpgv mpv mp1v m1v mp2v m2v
    File size : 1604296
    File size : 1.53 MiB
    File size : 2 MiB
    File size : 1.5 MiB
    File size : 1.530 MiB
    Duration : 3237
    Duration : 3s 237ms
    Duration : 3s 237ms
    Duration : 3s 237ms
    Duration : 00:00:03.237 (00:00:03;07)
    Overall bit rate : 3964896
    Overall bit rate : 3 965 Kbps
    Frame rate : 29.970
    Frame count : 97
    Stream size : 0
    Stream size : 0.00 Byte (0%)
    Stream size : Byte0
    Stream size : 0.0 Byte
    Stream size : 0.000 Byte
    Proportion of this stream : 0.00000
    File last modification date : UTC 2017-04-05 13:34:44
    File last modification date (local) : 2017-04-05 09:34:44
    Video
    Count : 312
    Format : MPEG Video
    Format settings, GOP : M=3, N=15
    Codec : MPEG-2V
    Duration : 3237
    Duration : 3s 237ms
    Duration : 3s 237ms
    Duration : 3s 237ms
    Bit rate mode : VBR
    Bit rate : 3964896
    Bit rate : 3 965 Kbps
    Maximum bit rate : 5000000
    Maximum bit rate : 5 000 Kbps
    Width : 1280
    Height : 720
    Height : 720 pixels
    Frame rate : 29.970
    Frame count : 97
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Bit depth : 8
    Bit depth : 8 bits
    Interlacement : PPF
    Bits/(Pixel*Frame) : 0.144
    Delay : 0
    Delay_Settings : drop_frame_flag=0 / closed_gop=1 / broken_link=0
    Delay, origin : Stream
    Delay, origin : Raw stream
    GOP, Open/Closed of first frame : Closed
    Stream size : 1604296
    Stream size : 1.53 MiB (100%)
    Stream size : 2 MiB
    Stream size : 1.5 MiB
    Stream size : 1.530 MiB
    Proportion of this stream : 1.00000
    Buffer size : 63488
    I've noticed a few variances, but still not sure how to completely replicate using ffmpeg.
    Thoughts?
    Oct 2005
    666th portal
    can you post/upload a small sample of the zvc? mediainfo doesn't even list an audio stream. is there one?
    Apr 2017
    The video does contain an audio stream somewhere, although it doesn't play audio in VLC, the file does play audio on the ZeeVee unit.
    The ZVC converter software "about" popup menu mentions that it uses a GPL version of FFMPEG to encode into a "known format," whatever that is?
    The audio stream info does seem elusive. Attached is a short sample of the video after it has been encoded using the ZVC converter.
    sample.conv.zvc.mpg is the converted file (normally ends in .zvc, but had to add .mpg at end so that it would upload), the file size is more than double, same video bitrate, so i suppose the audio is uncompressed pcm..
    sample.orig.mpg is the original clip before it was converted.
    Oct 2005
    666th portal
    i took a quick look through it and all i can tell you is that it has ac3 audio. but i don't see any sign of normal mpeg headers anywhere in the file so i'm not sure how they muxed it, which may be why nothing can play it with audio.
  5. HCenc author
    Dec 2006
    Netherlands
    The ZVC file is not an MPEG container but it looks like a video MPEG2 segment starting at 0x00000000
    Audio is AC-3 192 kbps and starts at 0x00173e8d until approx. 0x0018708f
    At 0x00187090 some kind of video and audio index starts.
    The video and audio can be muxed again into an MPEG2 file, it will play in VLC (with audio): zvc_remuxed.mpg
  6. So it's not interleaved?
    Apr 2017
    The folks at ZeeVee were so kind as to offer the source files to compile their converter on linux. I will see if there is any tweaking I can do, like multithreading, etc., although due to the method (described below) used to split up the video, I may be unable to clean up the choppy video compression appearance.
    Thanks everyone for your help thus far. I will try and keep you posted on the progress, and might even be able to provide a linux compiled app to share with anyone else that could use it.
    As for the source, respectfully I was asked to not share the source directly. ZeeVee email reply is below:
    Hi Jason,
    Below is a link to dropbox that has the source files in it for ZVc 1.2.
    Some information from our engineers –
    As the customer noted, we used ffmpeg to do the convert of the source video to MPEG2 program stream format. However, we did a couple of things to optimize the generated output file for playback on our hardware:
    • We separated the video and audio streams in to separate chunks. This allows the video and audio muxing code to more efficiently find the data to play out.
    • We do a pass over the video and audio data and generate an index array of each video and audio frame. This allows the playback code on the modulator to more efficiently find the start of a frame.
    The source code will build for both Linux and Windows.
    Under Linux, extract the archive with “tar xzf zvc.tgz” then run make at the root directory and it will build a zvc executable. In the root directory is a “notes” file that has more information on how to setup the Windows build environment. It’s much more involved.
    I do have to note, that the information and files are being provided to you “as is” and there is very limited support for it. Ultimately, if you have issues with ZvShow, we will want to use the converter from our website for troubleshooting.
    Regarding the post you put up on video help. Please don’t share the files directly, but feel free to note that we provided them to you. We would like to manage who we send the files to instead of posting them for general consumption. Hope you understand.
    Cheers
  8. HCenc author
    Dec 2006
    Netherlands
    The choppy video compression appearance is caused by the high quantizers used.
    For I-frames the (linear) quantization uses a quant value 62 which is the maximum --> worst possible quality.
    The P and I-frames use lower quantizers but still pretty high.
    Used quant matrices are standard MPEG2, so the flat 16 for non-intra.
    The ffmpeg MPEG2 encoder is very good, especially the later versions, setting it up can be problematic.
    @sneaker
    No, it's certainly not interleaved
