I recently purchased a Philips HTD5550/98 home theater unit and need to convert it to region-free. All the information I can find on the "5550" is from earlier versions and says to use the 99990 method. This does not work on my unit. I have tried every Philips conversion technique I can find and nothing has worked. Anyone have any suggestions?
Thanks!
FB
Actually, I have a Philips 3550 and it worked fine. I also have an LG which hacked easily.
BluRay - Windows 7 - Change region
By vidblue in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Feb 2017, 15:20 -
Change (not remove) Region code in ISO
By ckeays in forum DVD RippingReplies: 13Last Post: 10th May 2016, 08:23 -
Philips BDP2100/F7 Region B
By s-toon in forum DVD & Blu-ray PlayersReplies: 12Last Post: 6th Jan 2016, 09:37 -
change to region free Philips Blue Ray BDP 2500/12
By Helucy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Jul 2015, 12:40 -
region code for PHILIPS PD9015/12 ?
By purgui in forum DVD & Blu-ray PlayersReplies: 3Last Post: 28th Sep 2013, 16:52
