I am trying to use TSMuxer on Windows 10 to remove the AD audio track from a large number of .ts files on a HDD which has been salvaged from a Humax Foxsat HDR. The HDD is mounted in a Linux file server, and I am running TSMuxer from a command prompt in Windows 10, processing the .ts files via a samba share on the Linux file server.
The bat file that I'm using is designed to be run once in each folder that contains recordings:
If I do a test run, using a folder on the Windows 10 machine which I have copied some sample .ts files to, it works fine, producing output files without the AD track. If I run the same bat file from a command prompt against a folder on the Linux file server it produces a zero length output file every time. Here's an example of the output from one of the folders:Code:for %%i in (*.ts) do ( echo %%i echo MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 >> thisvid.meta echo V_MPEG4/ISO/AVC, "%%i", insertSEI, contSPS, track=5400 >> thisvid.meta echo A_AC3, "%%i", timeshift=-730ms, track=5401, lang=eng >> thisvid.meta echo #A_MP3, "%%i", timeshift=-458ms, track=5402, lang=NAR >> thisvid.meta d:\temp\tsMuxeR.exe thisvid.meta "%%~ni-fixed.ts" del "%%i" del thisvid.meta )
Does anyone have any idea why I get empty files when executed on the network share, but it works correctly on a local folder? I have write permissions to the network share (e.g. I can copy files to it from Windows)Code:W:\Video\Program_Name - Part___>( echo Program_Name - Part____20131101_0222.ts echo MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 1>>thisvid.meta echo V_MPEG4/ISO/AVC, "Program_Name - Part____20131101_0222.ts", insertSEI, contSPS, track=5400 1>>thisvid.meta echo A_AC3, "Program_Name - Part____20131101_0222.ts", timeshift=-730ms, track=5401, lang=eng 1>>thisvid.meta echo #A_MP3, "Program_Name - Part____20131101_0222.ts", timeshift=-458ms, track=5402, lang=NAR 1>>thisvid.meta d:\temp\tsMuxeR.exe thisvid.meta "Program_Name - Part____20131101_0222-fixed.ts" del "Program_Name - Part____20131101_0222.ts" del thisvid.meta ) Program_Name - Part____20131101_0222.ts Network Optix tsMuxeR. Version 2.6.12. www.networkoptix.com Warning! The file Program_Name - Part____20131101_0222.ts has a M2TS format. 100.0% complete Processed 0 video frames 100.0% complete Flushing write buffer Mux successful complete Muxing time: 26 sec
Results 1 to 1 of 1
tsMuxeR glitching output
By Flepcher in forum Authoring (Blu-ray)Replies: 0Last Post: 22nd Mar 2016, 10:23 -
Share livestreamer output over network?
By nmyshkin in forum Video Streaming DownloadingReplies: 0Last Post: 29th Sep 2015, 23:22 -
[tsMuxeR GUI 2.6.12] Empty Error Message (Screenshot)
By HaselnuesseTo in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Oct 2014, 06:52 -
tsMuxer Bluray output distorted
By JillB in forum Blu-ray RippingReplies: 10Last Post: 16th Aug 2013, 00:30 -
Is a NAS necessary for a ‘centralized’ home file share network?
By GLE3 in forum ComputerReplies: 16Last Post: 13th Jan 2013, 05:33
